4.2L Life expectancy? ?? - Ford Truck Enthusiasts Forums
Old 05-08-2014, 01:15 PM
alpha7mm alpha7mm is offline
alpha7mm is starting off with a positive reputation.
Right now I have 154,000 I do regular maintenance
Old 05-28-2014, 11:58 PM
gsmarcano gsmarcano is offline
gsmarcano is starting off with a positive reputation.
I have about 235,000. and still runs like a champ, but we don't push it too hard and use mobil 1.
Old 06-24-2014, 02:25 AM
W.O.T. W.O.T. is offline
W.O.T. is starting off with a positive reputation.
I have a 2001 with 225,000 on. It's an everyday work truck and personal driver. Rebuilt the tranny and put a new clutch in it, runs great though. My mechanic has an 02 with 460,000 on it!!!
Old 07-25-2014, 09:51 PM
james622 james622 is offline
james622 is starting off with a positive reputation.
I have a 2002 4.2 with 230,000 miles on it all it's had done is intake gaskets clutch and alternator. By far best truck I've ever owned, I'm a mechanic and sad to say I neglect it every single day and she just keeps goin been waiting for the motor to go kind of disappointed she hasn't ready to drop a fresh one in and tweak her up a bit. I'll never sell my old ford.
Old 07-29-2014, 06:08 AM
Moore558's Avatar
Moore558 Moore558 is offline
Moore558 is starting off with a positive reputation.
125K on ours. I'm planning in the future to replace the intake isolator bolts and clean the intake runners and EGR ports at the same time. Other than that, it's running strong.
Old 12-22-2014, 06:11 PM
buttz buttz is offline
buttz is starting off with a positive reputation.
352004 as of today!
Old 12-28-2014, 03:29 PM
Jon Wagner Jon Wagner is offline
Jon Wagner is starting off with a positive reputation.
I was getting near 200K when I got rid of mine. The engine was still running strong, the body was rusted too far along to keep it.
Old 02-02-2015, 08:23 PM
1saxman's Avatar
1saxman 1saxman is offline
1saxman is gaining momentum as a positive member of FTE.1saxman is gaining momentum as a positive member of FTE.
Holy cow! I would have to be 300 years old to rack up that mileage on mine - it only has 17,500!
Old 03-17-2015, 04:06 PM
Enterprise Blue Enterprise Blue is offline
Enterprise Blue is starting off with a positive reputation.
I'm at 158,300. Engine seems very strong although I've been working on some intermittent drive-ability problems. I'm sure I'll overcome them soon.
Old 04-25-2015, 03:12 PM
artfd artfd is offline
artfd is gaining momentum as a positive member of FTE.
Exclamation
I used to be an original owner of a 1983 F250 HD diesel pickup, and bought my 2001 F150 when it was 1 year old. I had some kind of rustproofing put on the F250 right after I bought it. When I junked the F250 after owning it for 30 years, the body was in very good shape considering all the winter driving and salt exposure it had. My 2001 F150 is extremely vulnerable to rust and has already had its radiator core support completely eaten away. The engine seems to be pretty durable, but the body is of poor quality.
Old 04-26-2015, 02:52 AM
bchambers bchambers is offline
bchambers is starting off with a positive reputation.
Quote:
My goodness. .... wash your poor truck sometimes! Salt eats every vehicle....
Old 04-26-2015, 02:54 AM
I have 211000. Runs great! No leaks. Stutters a little when i get on it from a dead stop. Probably a dirty injector or yucky plug..... I'll track it down one day.
Old 04-27-2015, 08:09 AM
Riverrandy Riverrandy is offline
Riverrandy is starting off with a positive reputation.
Like most things normal care (including washing) will go a long way. I bought a 1997 F-150 because it was very clean, small (compared to my 2002 F-350 crew 7.3), and had a bad (but running) 4.2 engine. I pulled the engine to replace with a reman, but had to drain all fluids before returning as a core. The "stuff" that came out of that engine was like black Mayonnaise. It stunk to high hell, and was just disgusting. I washed the block out with old ethanol gas so it would look good, and not get rejected on sight. There was so much play in the connecting rod bearings I could slip a paperclip between them. Research turned up the original owner did not change oil. 145,000 miles latter bearings were ground out.
Anyway this thing made noise, but still kept on running. When I put in the new engine, I expected better performance from the new block, but it was the same with out the knocking. A friend who had a similar work truck for years drove it with me, and said, "no that is how the 4.2 performed, and I (he) loves it". 2.5 years latter, I am still quite impressed even after towing a few large horses in a steal trailer for a couple of hours. and I love the turning radius (regular cab, short bed). Run on 4.2...
Old 04-27-2015, 04:59 PM
Exclamation
Quote:
I washed both trucks at about the same frequency over the years I owned each of them, drove them during the salty winters, except I drove the 1983 truck even more during the winter than the 2001 truck. I frequently crawled under both of them for routine maintenance & minor customizing. The 2001 is definitely more rust prone than the 1983 truck was.
Old 11-25-2016, 10:29 AM
Dane1987 Dane1987 is offline
Dane1987 is starting off with a positive reputation.
2000 f150 6cyl
Is everyone refferring to miles or kilometers
69 Bronco Vinford 1966 - 1977 Early Broncos 2 04-21-2016 12:27 PM
Wanted Truckin23 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 10-06-2014 09:20 PM
delete Myfreeford 1973 - 1979 F-100 & Larger F-Series Trucks 36 08-17-2014 10:24 PM
Go Back   Ford Truck Enthusiasts Forums > >
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
