07 e350 no spark help! - Ford Truck Enthusiasts Forums
Old 05-08-2014, 12:56 PM
Alexsogutta Alexsogutta is offline
Alexsogutta is starting off with a positive reputation.
I just did a head job on a 07 e350 and surprisingly everything went smoothly until I put it back together, I know every thing is there cause I took the time to label and mark everything but now I'm getting no spark at the coil but power to the coil. Please help lol
Old 05-10-2014, 10:37 PM
je5 je5 is offline
je5 is starting off with a positive reputation.
Welcome to the forum.
Swap that coil with another or check misfire count in mode $06 to see if you need to replace that coil.
150 or 350 advice needed trike1946 1968-2013 Full Size Vans 35 02-03-2015 10:33 AM
85 F350 460...no Spark! 90F250351 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 22 11-24-2014 06:25 PM
1993 E-350 Van's plugs stopped firing WillInTheWoods84 1968-2013 Full Size Vans 3 07-27-2014 05:25 PM
Needing help!!! Dougle07 1987 - 1996 F150 & Larger F-Series Trucks 3 02-24-2014 08:19 PM
07 E350 throwing code Epd444 1968-2013 Full Size Vans 0 04-19-2012 10:30 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
