Fuel Gauge Accuracy - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Fuel Gauge Accuracy
Old 05-08-2014, 11:50 AM
tractoman's Avatar
tractoman tractoman is offline
tractoman is starting off with a positive reputation.
Fuel Gauge Accuracy
Are the fuel gauges on these trucks notoriously inaccurate? My gauge seems to be pretty crazy below 1/2 tank and then I fill it up and it takes way less diesel to fill the tanks than I thought it would.
Old 05-08-2014, 12:25 PM
madMatador78's Avatar
madMatador78 madMatador78 is offline
madMatador78 is gaining momentum as a positive member of FTE.
Define crazy a little more. Is the gauge erratic?
It is possible for the pick-up in the tank to break so when you get below 1/4 or so, the truck will run out of fuel because it can't pump any more. I have this issue with the rear tank on my truck, about an 1/8 of a tank and thats it. I found out the hard way.
Old 05-08-2014, 12:43 PM
madpogue madpogue is online now
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
Pickup cracking or falling off has ZERO impact on the gauge reading. Still something to watch out for, below aprx 1/4 tank.
But yes, the gauge, like most fuel gauges, is a VERY rough estimate. Front tank is 16 gallons short-bed, 19 gallons long bed. Rear tank is 18 gallons.
Old 05-08-2014, 01:02 PM
Quote:
I understand that, just trying to get a grip on what its doing, the OP doesn't really say.
Old 05-08-2014, 02:01 PM
tractoman's Avatar
Sorry, to be more clear, it seems to drop faster when I am near and below 1/4 tank and that when the gauge appears to be near empty, I actually have more fuel than the gauge is indicating.
Old 05-08-2014, 02:22 PM
Hussler's Avatar
Hussler Hussler is online now
Hussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to allHussler is a name known to all
Quote:
Pretty Normal ... on mine it takes a long time to go from full to 1/2 then drops quickly. When close to the red line the most fuel I can get in there is about 12-13 gallons. Think Ford didn't want users to run out of fuel so they designed it that way.
Fuel gauge working but not accurate Ronnief150man 1973 - 1979 F-100 & Larger F-Series Trucks 5 12-04-2016 11:18 PM
Fuel from rear tank only tkisling 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 12-25-2013 10:47 AM
problem fuel gauge 87 E250 how solve? Super Econoline 1968-2013 Full Size Vans 8 04-27-2011 12:57 AM
Fuel Gauge works but reads way past full when filled and is empty when it reads 1/4 500FordF-150 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 03-10-2011 08:58 PM
Tying Dual Fuel Tanks Together? Pete Roberts 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 12 02-24-2011 08:29 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
