old member new project - Ford Truck Enthusiasts Forums
Old 05-08-2014, 11:04 AM
96XL 96XL is offline
96XL is starting off with a positive reputation.
hi guys, i just wanted to introduce myself. I am not new to the forum or to fords, however i am new to the F1 model. i just picked up a 52' F1. It has a flathead, reds headers, 12v conversion with VW stuff. otherwise it is pretty much stock with a recent backyard paint job. From what i can tell it has a bigger f2+ 4 speed trans with the granny low and the side PTO. The rear springs and diff may be off a later f-2+ truck? there seems to be a wealth of knowledge of these old fords and i am looking forward to being apart of The club. please take a look at the photos and let me know what you see, original or not. Like i said i am new to this model ford so i would like to identify exactly what i have.
i know everyone likes pics so lets get to it!
Old 05-08-2014, 11:05 AM
Old 05-08-2014, 12:13 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of52 Merc has much to be proud of
The 4 speed was an option in the F1, so it could very well be stock. From the looks of everything else, I wouldn't question it. The rear looks like the original Dana 44 with the addition of aftermarket overload springs. I have a parts F1 that has a set like that, made by Moog. All in all, it looks like a fine and fun rig. Welcome to the club!
Old 05-08-2014, 01:08 PM
ryans88gt's Avatar
ryans88gt ryans88gt is offline
ryans88gt is gaining momentum as a positive member of FTE.ryans88gt is gaining momentum as a positive member of FTE.
very nice... so what is "the project" part?
plans? or just drive it for now?
Old 05-08-2014, 01:23 PM
the immediate "TO DO" list is below.
pull the carb and fix the leak at the fuel inlet, it appears that the inlet was cross threaded at 1 point and it seeps fuel while running.
pull the overload springs and remove every other leaf on the rear spring pack. I hope to lower the rear 2" so i may have to relocate the hangers slightly to achieve.
put some time in rebuilding / replacing the drag link and tie rods. my drag link appears to be bent is it supposed to be straight?
i need to either find a new pair of rear steelies or straighten 1 of the rears i have. they have more of a positive offset than factory wheels pushing the outer edge closer to the fender lip. i am not sure how i like that.
new tires, fronts are 205/70 15 and are too short looking. rears are 235/75/15. my plan is to go with 215/75/15 all the way around with a cheap think whitewall (mini van tire). once i get the new tires on i can address how much drop i want on the front. i am thinking a 3" drop beam or using posies drop springs not sure what at this point.
i need to paint the wheels, i am trying to decide on the color. originally i was thinking red but that look is a little too popular for my taste. i dont mind the copper, maybe i will repaint with a center cap in chrome. thoughts?
Old 05-08-2014, 01:58 PM
underthebridgejim's Avatar
underthebridgejim underthebridgejim is online now
FTE fan
underthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputationunderthebridgejim has a superb reputation
Somebody has given that truck a lot of love and TLC at some point, very nice. Its good to have you back on the board with such a nice project.
Old 05-08-2014, 02:12 PM
tinman52's Avatar
tinman52 tinman52 is offline
Welder User
tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.tinman52 has a spectacular reputation.
Cool truck! Love the all black look.
I like the copper wheels alot, but tend to favor blackwall tires myself...
When pulling leaves, be careful not to pull too many, your suspension will get "mushy". I think I pulled 3-4 from the rear.
What rear gears does it have? 215/75 15 tires may leave you lacking some highway speed.
Old 05-08-2014, 02:19 PM
i like the black and the copper wheels are growing on me. rear gears i have not checked but i assume they are north of 350. what were the factory ratios? 373 and 392? yes, the rig is lacking highway capabilities now. phase 2 of my plan includes a s10 t-5 swap.
thanks for the heads up on the leaf springs. i was thinking 4 max. i dont plan to haul anything but dont want too much body roll. do you have any photos of your stance after you removed the leafs?
Old 05-08-2014, 04:03 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is online now
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Welcome to the BonusBuilt ward!
The bend in the drag link is normal; if you look at the orientation of the *****, the offset is needed to make a straight connection from pitman arm to spindle.
Standard rear axle would be a 3.92, which works well behind a T5. The T5 is a pretty involved swap, be sure you know what you're getting into! I went the Ford 9"/3.50 ratio and am pretty pleased, but something between 2nd and 3rd would be nice.
I second the blackwall comments, and staying tall. "Station wagon" tires just don't fill the wheelwells either. Your truck has later wheels, likely F-100 '67-on, which is a good thing in most respects but you won't be able to run stock hubcaps. What about some black dogdish's with the copper?
Old 05-08-2014, 04:17 PM
forgive me if it is obvious but what is the "bonusbuilt" term?
I have read up on the t-5 swap and there is a lot involved and that is why my current phase is to get the stance, wheels, tires figured out for the look i am after, then address highway drivability, it does sound a bit backwards but this is not my primary transportation.
now that i look at my front wheels, they appear to be later wheels as well.
Old 05-08-2014, 04:20 PM
ben73058's Avatar
ben73058 ben73058 is online now
ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.ben73058 has a great reputation on FTE.
Hey 96,
Welcome to '48-'56 Group!
Nice start - posting a lot of pics. No interior shots - how's it look in there?
You have a red engine, red battery, red horn, etc & then copper wheels.
I think it has to be red/maroon. We call that copper color burnt orange around here - maybe I'm just tired of getting run off the road by all of the college kids driving University of Texas burnt orange cars in town.
That's a nice truck. I'd just drive it a while before jumping on too many major items. How'd you come across it?
Ben in Austin
1950 F1
351W/AOD
Old 05-08-2014, 04:41 PM
the interior needs help. The seat is decent, the floors are good other than some stress cracks at the mounts (i am good at sheet metal work so not too big of a deal). it has a heater, not connected. no wipers, no working gauges other than the fuel (12v conversion). no headliner and some idiot cut holes in the doors for speakers so i need to patch all that back up. i will get some pics of the mess inside soon.
Old 05-08-2014, 05:20 PM
ALBUQ F-1's Avatar
postin' fool
BonusBuilt = 48 - 52 trucks
Old 05-08-2014, 07:12 PM
tinman52's Avatar
Welder User
Quote:
I think I pulled 4 from the back and 3 from the front.....plus de-arched the fronts. Stock front axle.
I did the T-5 swap behind the flat V8 also.
Old 05-09-2014, 12:18 AM
51PanelMan's Avatar
51PanelMan 51PanelMan is offline
51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all51PanelMan is a name known to all
Stock rear end ratio was 3.92 and 4.11 for 51-52 trucks. My 51 currently has 15" wheels with 215/75/15 thin white wall tires. I put bullet style hub cover and bullet style lug nuts. Kind of a poor man's spider caps. The wheels are the correct ones with the innie nubs. I'm looking to sell them (have all 5). PM me if you're interested. The rubber is practically new. Bullet lug nuts and hub covers not included.
Perhaps this will give you an idea of the look.
Weather cant stop me! put the F1 to work this weekend 96XL 1948 - 1956 F1, F100 & Larger F-Series Trucks 20 01-10-2017 01:43 PM
ignition switch questions 1950 f1 96XL 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 03-06-2015 11:20 AM
anyone have some extras that are in the way? 96XL 1948 - 1956 F1, F100 & Larger F-Series Trucks 5 02-15-2015 04:52 PM
is this a correct carb for a 1950 239? 96XL 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 02-09-2015 09:00 PM
gearing up for a transmission swap. need some help 96XL 1948 - 1956 F1, F100 & Larger F-Series Trucks 4 06-06-2014 11:31 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
