Diesel Leak
Diesel Leak
Hey guys, I have had a diesel leak for quite some time, and have just recently identified where it is coming from, but need to know what it is.
Any info would be of great value to me to know what this part is, and why it might be leaking, and of course lastly the best way to resolve the issue. As I just put a new SouthBend clutch in and don't want diesel dripping down into the bell housing and getting onto my new very expensive clutch.
So as you can see from the picture below it is on the right side of the fuel bowl, the part that is leaking is circled in green and then the 7 dots indicate where it is leaking from. It is a pretty stead stream of diesel that is coming out when the truck is running.
Thanks for any help you guys can offer.
Sam
Sam
That is the fuel filter restriction sensor, not WIF. It can be removed and a pipe plug used as stated. Myself I like to have the sensor in there to help see what is going on with the fuel system.
diesel o-rings at
Navistar Fuel Bowl Filter Restriction Sensor
$30.78 plus get a tube of Gasoila thread sealer 1 tube about $10.00 will last you a lifetime superior to Teflon Tape as its made for sealing petroleum parts Bob has it in stock as well
Resendiz
20
10-16-2016 05:07 PM
MrCBofBCinTX
08-26-2010 12:34 PM
