Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460)
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
Old 05-07-2014, 07:21 PM
mdh1701 mdh1701 is offline
mdh1701 is starting off with a positive reputation.
EFI 429 question
Just trying to get some knowledge for my own curiosity. I know that at some point, the EFI 460 switched back to the "pre-smog" timing set, I am wondering if they did something similar when 429 HD was similarly switched over to EFI? And what heads did these things get? Or are there different heads depending on year, like the 460? Thanks in advance!
__________________
Moses Hughes aka mdh1701
1994 F350 DRW XLT CCLB 460/5-speed 4x2. WANTED: Bullnose 250HD or 350 4x4 w/460 power and a stick, fixer upper OK!
Old 05-09-2014, 02:13 PM
Bump. Still looking for any info anyone might have. Thanks!
__________________
Old 05-12-2014, 05:55 PM
Re-bump! I guess I'm reaching out to numberdummy. If anyone has any info it would be greatly appreciated!
__________________
Old 05-13-2014, 09:10 AM
cbakker's Avatar
cbakker cbakker is offline
cbakker is starting off with a positive reputation.
I did a little digging myself to appease my curiosity. I would assume the timing went back to straight up, but not sure when. 429's were not EFI until ~92 give or take a year. If you have the timing gears exposed, you can tell if they are straight up by looking at the crank gear. If the dot is directly lined up with a tooth, it is straight up. If you can see that it is off center of the tooth, it is probably retarded.
As far as the heads go I don't know anything unless they are the same as 460 heads. I know they did have 4v heads for a while, but not sure which years.
Why not put 460's in the HD trucks? I don't get it...
__________________
cbakker
'97 F-250HD CCSB
460 w/Banks PowerPack
Full Emissions Delete
Old 05-13-2014, 10:22 PM
The heads weren't 4v, the 4v on the fender badge meant a 4-barrel carburetor. 370s are the same way, both also came with 2-barrel carb.
People have dropped 460's into HD trucks, but it requires a little work, since the good 460s are external balance, 370 and 429 are internal. Why didn't Ford do it? Probably didn't want to give the up-and-coming diesels too much competition...
__________________
Old 05-13-2014, 10:50 PM
ArdWrknTrk's Avatar
ArdWrknTrk ArdWrknTrk is offline
<---Dog is my co-pilot
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Straight up roller timing sets came back to the 460 with EFI for the '88 model year.
All D9TE blocks were equipped with four barrel carbs.
Only some '70's vehicles had 2 barrel carbs (and some came with an oddball spreadbore!)
E7TE's were the first EFI 460 heads.
They were revised in 1993 with the F3TE casting number.
I'm sorry, I can't give you much about variations of the big snout 429's found in medium duty trucks.
That massive crank end and the shorter stroke are the main reasons for using the governed 429 in the larger trucks.
429 has less piston speed for the same rev's while pressed against the governed redline for hours on end.
__________________
Jim (AKA Princess Glitzhooter)
'87 F-250
460, 4V 0-80457s, Edelbrock Intake, Saginaw PS Pump, BW 1356 4x4, 4.10 10.25", 130A 3G Alt., PMGR starter, ZF-5, - Lil' Red
http://i246.photobucket.com/albums/gg117/donjamer/FTE%20Pics/blumax500-1-1.jpgFTE Fraternity of Blue Max
Old 05-14-2014, 08:28 AM
cbakker's Avatar
Quote:
Originally Posted by mdh1701 View Post
The heads weren't 4v, the 4v on the fender badge meant a 4-barrel carburetor. 370s are the same way, both also came with 2-barrel carb. People have dropped 460's into HD trucks, but it requires a little work, since the good 460s are external balance, 370 and 429 are internal. Why didn't Ford do it? Probably didn't want to give the up-and-coming diesels too much competition...
Thank you for the correction mdh. It was strange that I couldn't find actual 4 valve heads online.
__________________
cbakker
'97 F-250HD CCSB
Old 05-14-2014, 06:05 PM
Only some '70's cars had 2 barrel carbs (and some came with an oddball spreadbore!)
Thanks Jim, you always have good info!
Just wondering, did the 87 Cali trucks with EFI have straight up timing, or was it a universal 88 thing?
cbakker, yeah, lots of people see 4v fender badges and think 4-valve, you're not the first! I had a friend who swore up and down he had 4v heads on his 370, right up until we rebuilt it, then he finally believed me! Oh the good old days...
__________________
Old 05-14-2014, 06:47 PM
ArdWrknTrk's Avatar
As far as I know all EFI 460 trucks had straight up timing sets.
The SD trucks and the very late (1996-'97)Cali MAF trucks.
There are definitely different heads for stationary 429 & 460 industrial/marine engines.
I'm not sure about engines that had to meet Federal emissions regulations for road use.
RHP was offering updated D3 style iron castings with better flowing exhaust ports.
RHPD3Index
What has you interested in the EFI 429's Moses?
__________________
'87 F-250
Old 05-15-2014, 12:23 AM
Jim, I was thinking that if someone came across a carbed 370 or 429 and lived somewhere that doesn't strictly enforce emissions on old crap, they could use the same method for easy power us 460 guys enjoy, and the only way it would work is if the EFI 429's had straight up timing like the EFI 460s, since the HD engines have the big snout. I'm always thinking of stuff like this, just for curiosity. Amazing as much as I know about these things I come here and still learn more stuff! I don't know it all, and have been schooled a couple times here. And I greatly appreciate it! I'd rather someone correct me when I'm wrong than propagate falsehoods!
__________________
Old Yesterday, 09:22 AM
taylorbickett5's Avatar
taylorbickett5 taylorbickett5 is offline
taylorbickett5 is starting off with a positive reputation.
so the HD 429 wouldnt necessarily be a good choice if i wanted to take one from a 96 efi f700 and put it into a 79 f150?
I guess i could always swap rotating assemblys. how well do the stock efi heads flow? i was just going to hop over to pricemotorsports and buy their carb adapter to switch from efi to carb (mainly because the engine didnt come with the ecm or harness..)
__________________
1979 f150 lariat 4x4
429 BBF w/ c6 trans
Old Yesterday, 11:05 AM
ArdWrknTrk's Avatar
You can't put an internally balanced crank in a D9TE block.
The counterweights won't fit
External balance was a running change during the '79 model year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Similar Threads
engine stands and mounts for 1974 f 250 fordsrgrt 1973 - 1979 F-100 & Larger F-Series Trucks 3 03-23-2014 03:17 PM
EFI 460 Performence questions 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 6 02-23-2013 01:54 AM
7 L EFI V8 engine abrojal Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 3 01-31-2013 08:03 PM
will 1972 429 2blgo to 79 460? 707crewlover Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 4 10-20-2012 09:27 PM
can it be done? smokenchoken Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 07-26-2012 10:44 AM
Powered by vBulletin® Version 3.8.7 AC1
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
