F600 with 370 Lima 2bbl, HELP
Old 10-20-2014, 06:28 PM
philsteel's Avatar
philsteel
philsteel is offline
I am fixing my 1985 F600 truck but can't seem to find valve springs, and valve spring retainers. I found the melling intake valve springs (VS-835), but not the exhaust ones and bought the sealed power VS-803, a bit smaller than the recommended melling VS-836 (which are not available)... Valve spring retainers?? no one knows which ones to use. I bought both comp cams
744-16, and 743-16 retainers to see how it fits...Does anyone here knows anything about the 370?
Phil
Old 10-22-2014, 01:03 AM
85e150's Avatar
85e150
85e150 is online now
Received 1,585 Likes on 1,292 Posts
NAPA shows them, says 370/429 are the same for many model years:
NAPA AUTO PARTS
Have you tried to find a Ford parts catalog?
Tools, Catalogs & Supplies - Parts Catalogs & Videos - HiPo Parts Garage
Old 11-16-2014, 04:06 PM
philsteel's Avatar
philsteel
OK, found the parts. Now that am done, the motor backfires as soon as i touch the throttle. Does ok at high idle, but can't really drive it. High rpm is ok. Could this be a burnt valve? i did find a broken exhaust valve spring...i May get a replacement motor from rockauto.
carguy3j
05-20-2017 09:04 AM
Mudman
05-05-2006 08:58 PM
RawPower
03-08-2005 10:21 PM
MercM47
10-24-2003 11:57 AM
jcd155
11-19-2002 06:25 PM
Quick Reply: F600 with 370 Lima 2bbl, HELP
