Front leaf spring bushings - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 05-07-2014, 04:02 PM
kc5mhb's Avatar
kc5mhb kc5mhb is offline
kc5mhb is starting off with a positive reputation.
Hi,
Been searching around but not finding any information on the front leaf spring bushing on my 2000 F250 SD 4X4. Its been pulling to the left for a bit while braking. Took it to a highly trusted mechanic and he replaced calipers and hoses on the front. Made it a little better but it seems that once the brakes heat up some it still pulls to the left the closer you are to getting to a complete stop. He came up with two possibilities after much searching: Steering box or spring bushings.
Anyone else have this diagnosis? If so did you replace the bushings and the problem go away?
Old 05-08-2014, 09:25 AM
ATS Junior's Avatar
ATS Junior ATS Junior is online now
SPONSOR
ATS Junior has a very good reputation on FTE.ATS Junior has a very good reputation on FTE.ATS Junior has a very good reputation on FTE.ATS Junior has a very good reputation on FTE.
Worn out bushings could cause some issues up front because things are moving around. Not exactly sure what the issue could be for you. If you need bushings let me know, I have ones you are looking for and they are a direct replacement.
-Junior
__________________
www.ATSsprings.com
Ask About our Ford-Truck Forum Discounts! (1-888-943-8287)
"We sell parts and experience"
Old 05-14-2014, 12:00 PM
kc5mhb's Avatar
Problem found!!!! Turns out I have a bad set of brake pads on the front. Being replaced right now!!!!
Old 05-14-2014, 12:13 PM
ATS Junior's Avatar
SPONSOR
Happy to hear you got everything figured out!
-Junior
__________________
www.ATSsprings.com
Leaf spring bushings. unibody62 1961 - 1966 F-100 & Larger F-Series Trucks 8 01-13-2017 05:33 PM
New leaf springs v new bushings Borgia 1999 to 2016 Super Duty 3 09-24-2016 12:03 PM
Leaf spring bushing green_95 1994.5 - 1997 7.3L Power Stroke Diesel 4 05-31-2016 08:46 AM
poly bushings in rear leaf springs - no go LCAM-01XA 1987 - 1996 F150 & Larger F-Series Trucks 18 03-17-2010 10:40 PM
Progress removing rear leaf springs F250Rob 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 10-08-2006 07:55 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
