7.3L Powerstoke Tank Switching Problem - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-07-2014, 03:15 PM
jjpski jjpski is offline
jjpski is starting off with a positive reputation.
Question 7.3L Powerstoke Tank Switching Problem
I have a 96 Ford F250 Crew Cab and having a tank switching problem.
The truck was in storage for 3 and half years. While it was in storage someone was driving and starting one a week. When I picked it up from storage the fuel indicator stopped working on both tanks and it would not switch tanks. Currently the vehicle only draws fuel from the front tank which had to be replaced because the tank rusted through.
I have already replaced the tank switching valve which now it indicates fuel levels. Verified by siphoning some fuel from the rear and putting in the front. one problem solved. But it still will not draw fuel from the rear tank. If I switch the truck to the rear the tank it runs fine but it is still running off the front tank. I have checked power to the valve in the front and rear positions and have 12v on each system. Does the tank switching valve have anything to do with fuel level indication? Does the tank switching valve ground through itself to switch tanks? Any tips are appreciated.
Jared
Old 05-07-2014, 04:07 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
Yes, there is a fuse in the in cab fuse box that controles the fuel selector selinoid that also is tied to the fuel gauges. Setting that long, the selector valve may be stuck in one position. You should be able fo hear a faint zipping sound from the tank selector when it is changed from one tank to the other.
Dual tank fuel selector valve khaitan 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 28 12-03-2016 09:38 PM
Strange problem with dual gas tanks. Phobia16V 1987 - 1996 F150 & Larger F-Series Trucks 30 06-05-2016 07:32 PM
'94 460 dual tank gas-fuel moving from rear tank to front? Ex-ChevyOwner Fuel Injection, Carburetion & Fuel System 2 10-07-2015 10:14 PM
Fuel from rear tank only tkisling 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 12-25-2013 10:47 AM
89 F150 4x4 Dual Fuel Tank Switch predaina 1987 - 1996 F150 & Larger F-Series Trucks 29 03-29-2011 08:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
