Tint a sprayable bedliner?
Old 05-07-2014, 05:51 AM
yetiman38237's Avatar
yetiman38237
yetiman38237 is offline
One thing I have left to do is spray in a new bedliner. I had a buddy do it over 10 years ago and it was looking faded and beat up a little so I am going to be tackling that in next week or so. I do have some paint left over (a little over a qt) but don't want to end up with a sick gray looking mess. Has anyone ever tried to match paint with bedliner and have any tips?
Old 05-08-2014, 06:40 AM
gfw1985's Avatar
gfw1985
gfw1985 is offline
Cranky Old Guy
UPOL Raptorliner sells a tintable bedliner. There may be others, this is just the one I use. A clearish color made to mix with auto paints and UV resistant. Not to be confused with the normal black.
Old 05-08-2014, 07:32 PM
yetiman38237
Thanks, I decided to use google *gasp* and found that exact brand on Ebay pretty reasonable with instructions on how to mix. I do believe I will be using that.....only thing with this pearl being a 3 stage paint I am unsure how to make it look like the truck instead of bright white. I am thinking if I mix the pearl in with the paint it should be pretty close.
Old 05-10-2014, 09:58 AM
GLR's Avatar
GLR
GLR is offline
I used this (Rock-it)
SEM Products | Automotive Repair and Refinishing Products
rolled it on. But, like paint, it will show scratches if you slide stuff on it.
Old 06-06-2014, 06:56 PM
yetiman38237
Well I bought the Raptor from Upol, got a kit and tinted like the instructions. Only thing was my bed was black from original bedliner so it had some spots that weren't completely filled in white. I managed to get my hands on a single bottle and touched it up. I would recommend using 2 full gallons with a color change. I looks good but not sure how durable this stuff would be. I don't plan on abusing it so it should be fine.....looks nicer than black bed with white truck imho
Old 06-07-2014, 06:34 AM
JWA's Avatar
JWA
JWA is offline
Received 1,393 Likes on 1,102 Posts
MonstaLiner is another brand of tintable bed liner type material--pretty cool stuff actuall: Monstaliner do-it-yourself roll-on truck bed liner outperforms Herculiner Bed Liner, Duplicolor and Rustoleum Road Warrior
Old 07-28-2014, 10:57 AM
liftnw8z's Avatar
liftnw8z
liftnw8z is online now
(CL) Team Brahma
This is something I am looking into. I just bought an F350 that is white, and the bed is sound but a little scraped up. I want to do something for protection above paint, but don't want a black lining product. None of the pro lining shops in the area do tintable stuff (for whatever reason I'm not sure).
Seems like Monstaliner and this Raptor stuff are worth looking into.
Old 07-28-2014, 02:45 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
I really like my bedrug......I have hauled steel, wood, sod & concrete...never an issue but I do lay a tarp down with dirt so it makes cleanup easier.
Old 08-04-2014, 05:49 AM
yetiman38237
I haven't put anything in bed that can actually scratch it so I can't comment on durability. My gut says it would probably scuff if I were hauling concrete blocks or something........
Old 08-14-2014, 05:36 AM
karlduke's Avatar
karlduke
karlduke is offline
Just curious if bedrug will help trap the water underneath it.
Old 08-14-2014, 07:22 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
No...there is a dense foam type backing which is designed to match the bed, making the surface dead smooth.....water to date has not penetrated and there is no moisture issue.
Old 08-22-2014, 11:22 AM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Al's liner is also tintable and I have had Very good luck with it
Old 08-22-2014, 02:05 PM
liftnw8z's Avatar
liftnw8z
(CL) Team Brahma
I've looked into this one too. I like what I see.
Gorgoth
Paint & Bodywork
07-19-2009 11:58 PM
rugermack
Paint & Bodywork
05-17-2008 09:36 PM
Boss50
Paint & Bodywork
07-16-2005 01:45 AM
mattselland
Paint & Bodywork
07-13-2005 02:41 PM
pshadwick
Paint & Bodywork
10-21-2003 05:33 PM
Quick Reply: Tint a sprayable bedliner?
