HEIGHT?
Old 05-06-2014, 07:36 PM
MrBlue54's Avatar
MrBlue54
MrBlue54 is offline
Trailering
HEIGHT?
We have a 54 F-100 with a dropped straight axle. We would like to swap out the drop axle for a MII suspension. We really do not want to raise the front of the truck with the swap. Currently the front wheel opening is 25-inches front the ground to the lower lip.
So does anyone know the fender lip height with the MII setup?
Thanks,
MrBlue54
Old 05-06-2014, 08:45 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
I have the MII from TCI with dropped spindles and I am now sitting at 24".
Old 05-06-2014, 11:20 PM
smallello's Avatar
smallello
smallello is offline
If you each have different wheel/tire diameters the measurement will not be equal. The wheel diameter will effect the measurement from the ground.
Measure from the center of the wheel (not the ground) so that the wheel diameter has no effect.
Old 05-07-2014, 03:33 PM
B/B ford's Avatar
B/B ford
B/B ford is offline
Clean & Classy
24" tire diameter
spongecop
2009 - 2014 F150
09-10-2019 08:38 AM
F100 AMG
05-20-2016 09:23 AM
iowa79superdent
03-14-2015 12:28 AM
gworks
1999 to 2016 Super Duty
10-27-2007 03:08 PM
dj53
05-03-2006 07:31 PM
Quick Reply: HEIGHT?
