sensor bypass - Ford Truck Enthusiasts Forums
sensor bypass
Old 05-06-2014, 08:28 PM
HotRodTroy HotRodTroy is offline
HotRodTroy is starting off with a positive reputation.
sensor bypass
How do I bypass the sensors in the cats?
Thanks
Old 05-06-2014, 09:14 PM
Sorry, I have an 06 F150 SCREW 5.4. The OBD says cat right bank. I'm trying to bypass the sensors and eventually cut out the cats and replace the muffler with a set of cherry bombs.
Thanks again.
Old 05-06-2014, 09:19 PM
P.Bronner P.Bronner is offline
P.Bronner is gaining momentum as a positive member of FTE.
Its going to take an aftermarket tuner that ignores the feedback from the cats.
Can I bypass exhaust filter and cat plhlt89 1999 to 2016 Super Duty 3 08-04-2011 07:54 PM
02 sensor bypass? deadeyedevon Exhaust Systems 3 08-04-2011 09:07 AM
IAT Sensor MOD pro/cons bwebb03 Excursion - King of SUVs 2 07-01-2010 03:12 PM
Nock Sensor- how do i bypass it torque head 1978 - 1996 Big Bronco 16 05-28-2010 01:46 AM
High Pressure Oil Sensor, Can I bypass it? eli98 1999 to 2016 Super Duty 4 05-16-2010 12:05 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
