Compressor question
Brad
You are right to not use Teflon tape. Teflon tape is an excellent thread lube but a poor sealant plus it invariably gets into your controls and fouls them up.
You can't go wrong with locktite pipe dope. It flows during makeup but once oxygen is excluded it hardens, takes anywhere from 5 minutes to 1/2 hour to set.
People usually don't understand the dynamics of leaks at pipe threads. Pipe threads are tapered. That is the "T" in NPT, national pipe tapered. In order for the fluid to leak through the thread it must follow the thread all the way up in the root diameter of the thread. If you break that path at only one spot along its path you have stopped the leak.
Non hardening dopes can get blown out of the threads at pressures higher than about 50 psi.
pipe
the plug was just a test. It was a new plug and the threads looked ok. I have to run about 25 feet of pipe, elbows, valves and such so I want to makes sure it holds before I take the time to build the whole thing. That small leak as you call it dropped 10psi in about 5 minutes. Is it unrealistic to have a system that is leak proof. ie after a week or so do you guys have to pump up your air compressors.
I don't know if I'd go so far as to say unrealistic, because theoretically you should be able to build a system that doesn't leak. After all, they can do it with natural gas systems. But in all the shops I've worked in over the years, and there's been quite a few, I've never been in one that didn't have the little background hiss of an air leak somewhere. If you think about the number of fittings and connections in an air line system, hard lines, hoses, couplers and connectors, tools, etc., it's highly unlikely you'll ever have one that seals perfectly.
I have quite a few lines from my compressor all feeding from the outlet where I have a ball valve. When I am not using the air I just close the ball valve. If I have a hose or two hooked up to any tool (impact, nail gun, etc.) they wont have air in them about an hour or so later because of the quick disconnect ends. Other than that I have no leaks and I used Thread Sealant with PTFE (Polytetrafluoroethylene) which works really well.
Those threads are tapered. If the threads on the hole are too big or the threads on the plug are to small, no amount of thread sealant will solve your problem. Speaking of hole threads being to big, did I ever tell you about the girlfriend I had in the Arny?
Brad
coolfeet
20
04-24-2019 07:04 AM
72CC428
07-13-2018 01:21 PM
SleeprLegend
13
04-22-2011 08:43 PM
