My first rebuild
#272
#273
You got that right! He he .
Well let's derail further lol
I saw a cab at the truck stop that used a Bluetooth connection for the mic.
Pretty fly for a white guy:-) or should Ijust do an ol reliable cobra classic?
Not sure what I will do on an antenna with my truck cap...and my truck barely fits in the garage so it will be a challenge to do...
#275
Well fellas. We'll see what tonight brings. I'm milking right now but I have been plugging away on the truck all day. Hopefully I can get it started tonight. All I have left( to run it. Not drive it. A ways from that) is the top rad hose and fill with coolant. The 4 motor mount nuts on the cross member. And the batteries. By the way, what lower rad hose do you guys use for the ih water pump. I got a 91-93 dodge cummins lower hose and it was to short. I went back and got a 7.3 idi lower hose from a van and it works perfectly.
#278
#282
Ok I got it to fire by adding to the hpop. It ran for maybe 3 seconds and died. I did it again and same thing. Also lots of cranking in between. By the way all of a sudden the starter began to act brand new. Idk why. So far I haven't noticed the oil pressure gauge on the dash move so I got underneath. When I put the oil filter on it was 3/4's full. Now it's 3/4's full. So now the big question. Is there a way for the oil to go back to the pan without it ever reaching the filter. Ps there is no external leaks. Oh except a small coolant leak.
#283
on
1 Post
#285
on
1 Post
If the LPOP isn't working, it wouldn't fill the filter. I think there is a small plug on the driver side right at the edge of the block where the trans adapter meets the block that is a pressure port. It is straight back from the oil filter and has a square head on it. I'm almost certain that is a pressure port.
