My first rebuild - Page 9 - Ford Truck Enthusiasts Forums
My first rebuild
  #121
Old 08-14-2014, 06:35 PM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is online now
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Yes the old girl got a complete valve job. Seats ,seals ,valves ,springs and retainer clips. Also new injector cups
  #122
Old 08-17-2014, 12:06 AM
I need help. On the top of the block, In the valley at the front right behind the from cover is a hole that if I recall was a plug with spring and ball bearing. It is missing. I pulled it out and put back in before sending it to the machine shop. They removed it but must have discarded it. I'll call them Monday to see if they may still have it but I doubt it. Anybody know where I could find such a thing. I was thinking international most likely but I will probably have to order it. Any other ideas
  #123
Old 08-17-2014, 05:22 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Quote:
I'd say IH will be your best bet on that. I got a new o-ring for that plug from IH.
  #124
Old 08-17-2014, 10:54 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
That plug gets an o-ring? I just assumed it was another pipe plug and left it be. I hope it doesn't leak on my new paint job!
Bill - do I recall correctly that you thought your was leaking, but it turned out to be your front cover? Or do I have that backwards.
Anyway - good luck finding that plug spring and o-ring (apparently:-) ). What does that thing do? A check valve for the hpop or something? Can that even come out with the hpop reservoir in place?
  #125
Old 08-17-2014, 11:15 AM
fordpride's Avatar
fordpride fordpride is online now
fordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant futurefordpride has a brilliant future
Yes it has a oring
I have some of the part #'s
HPOP Quick Fill Check Valve
O-ring F4TZ-6674-A
Int’l 1815980C1
Ball F4TZ-6674-B
Int’l 13722D
Seat F4TZ-6674-C
Int’l 1815952C1
  #126
Old 08-17-2014, 01:42 PM
Quote:
Originally Posted by fordpride View Post
Yes it has a oring I have some of the part #'s HPOP Quick Fill Check Valve O-ring F4TZ-6674-A Int’l 1815980C1 Ball F4TZ-6674-B Int’l 13722D Seat F4TZ-6674-C Int’l 1815952C1
Cool Mike. That makes it a lot easier. You don't happen to have the spring number do you? Preferably in international
  #127
Old 08-17-2014, 08:27 PM
fordpride's Avatar
I don't. That's all I got
  #128
Old 08-18-2014, 04:15 PM
I got the pieces ordered. 5-6 business days. Thanks again mike. Those numbers made it a lot easier
  #129
Old 08-25-2014, 02:54 PM
Well guys, it looks like whatever little time I had for the rebuild is now put on hold for a bit. I did get the oil pan stripped down to bare metal saterday and was planning to paint it Sunday so I could get the peices on but instead I did this
I did it on a round bale spike and managed to get it right down to the tendon. I didn't damage the tendon but it sure doesn't feel good. I can move my hand but have to be very careful. I do have some pics of the motor though
Taping for paint
The bottom end all assembled
Welded oil jets
Nuts welded to the exhaust manifold bolts that I stripped
My girls turned 7 on saterday so we had a big do for them. The candles are really getting bright
  #130
Old 08-25-2014, 03:23 PM
The wife kids and I took my nieces to Harrison lake the other day too. It was nice. We launched on the fraser river, went up the Harrison river then a little ways up the lake and found a beach with shallow water for the kids. The trip was about 35 km from the boat launch to the beach. The kids loved it
Here's a pic of the route
And a few of the trip
  #131
Old 08-25-2014, 06:28 PM
427 fordman's Avatar
427 fordman 427 fordman is offline
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Nice pics Nick! Take care of that hand. Bad place for a wound for sure.
  #132
Old 08-25-2014, 06:46 PM
Quote:
Tell me about it. It's my dominant hand too. So simple tasks like brushing my teeth or opening a door take some extra thought. I'm sure it'll be good in a few days.
  #133
Old 08-25-2014, 09:01 PM
ReBilld's Avatar
Ouch Nick!!! I feel for you bud. I ran that nail in my hand a while back but it wasn't near that bad. Hope it heals up quick. Nice pics too. Great looking family you have bud!
  #134
Old 08-25-2014, 09:28 PM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
That must hurt man! Ouch
  #135
Old 08-25-2014, 10:06 PM
ColoradoFordBoys ColoradoFordBoys is offline
ColoradoFordBoys is starting off with a positive reputation.
I have been trying to keep a watch on this overhaul because I am in the same boat Just dropped my block off at the machinest today. with .010 pistons from clay. I was curious what piston to cyl bore clearance is because I am seeing .0055 seems to be the recommended standard but my 94 7.3 DI ford service manual is calling for for .0036-.0048?? Just cusious what you did. Another question what did you go with for ring gap?? P.S. Sorry about the war wound!!
Rebuilding a 390 need some advice on internals 99ARTaco 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-17-2017 09:08 AM
engine rebuild kevintoupin 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-14-2016 11:33 PM
Can anyone match me on engine swaps? Red454sedgwick Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-26-2015 08:06 PM
machine shop tjg1964 1987 - 1996 F150 & Larger F-Series Trucks 7 09-08-2015 09:53 AM
1946 v8 239 rebuild kit c249a 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 06-09-2015 07:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
