My first rebuild
#481
Do you mean the heater fan. If so no It wasn't. A/c is getting fixed next week. . I saw the pillar pod reset which is connected to the stereo power. One other thing is the obd port is not mounted to the dash. I wonder if my wife kicked it without noticing. Not that that should cause a problem buuuut.
#482
#484
I agree with Nate. I assume you lost ignition power if the pillar gauges reset. Check the grounds (batteries to front cover and the small grounds that bolt to both inner fenders and the core support), battery cables, starter solenoid connections, and the firewall connection next to the PCM connection. That firewall connection connects to your under dash harness and if that came loose somehow it would cause everything in the cab to lose power.
#486
Holy cow I've been busy. I bought oil and filters most likely 6 weeks ago. Not done yet, plus my brakes went out about 2 weeks ago, not fixed yet. With planting lately and getting the crops off and all the break downs I've had this year I've had no time. On another note I've probably only put 50 miles on my truck in the last 6 weeks so I guess it's not to bad lol
#489
too late lol. Hopefully things start to slow down now
It is getting pretty bad around hee lately
427 fordman
244
05-09-2019 07:31 PM
Anderson80
11-13-2018 10:50 AM
Millermadness11
48
09-09-2015 12:44 AM
yellow truck
03-02-2011 09:58 PM
