My first rebuild - Page 11 - Ford Truck Enthusiasts Forums
My first rebuild
  #151
Old 08-31-2014, 07:43 AM
MOOSE_MACHINE's Avatar
MOOSE_MACHINE MOOSE_MACHINE is offline
MOOSE_MACHINE has a good reputation on FTE.MOOSE_MACHINE has a good reputation on FTE.
Yea. I stared at it for about 15 min before realizing I had no choice
  #152
Old 08-31-2014, 08:40 AM
oldbird1965's Avatar
oldbird1965 oldbird1965 is online now
oldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to beholdoldbird1965 is a splendid one to behold
Looks great man, I'm jealous!
  #153
Old 08-31-2014, 09:10 AM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
Looking good! Are those SD intake plenems?
And I've had about a 1/2 dozen of those 'did I torque that' moments on my build so far :-)
  #154
Old 08-31-2014, 10:13 AM
Quote:
Originally Posted by OldWoodsDiesel View Post
Looking good! Are those SD intake plenems? And I've had about a 1/2 dozen of those 'did I torque that' moments on my build so far :-)
Yes they are sd plenums. The worst part about the torquing was I had put the pan in the day before. The goop was set up just enough to be a real pain in the a$$. I went with the black and red to go with the truck. But after I saw your motor I've kinda been regretting the color choice. No turning back now
  #155
Old 08-31-2014, 11:36 AM
Quote:
The grass is always greener! I was looking at your clean, black block and thinking maybe I should have done all black! My truck will be all black, but I decided to change it up under the hood. Still no colors, just different monochrome tones.
And was the new goop tougher or easier than 15 yr old goop to remove?
For what it's worth, I did find out that acetone is a great remover of that stuff. You can't spray it on for fear of overspray, but you soak a rag in it, then wipe down whatever goop didn't scrape off and you're clean as a whistle!
  #156
Old 08-31-2014, 12:26 PM
Old goop is way easier. It hadn't fully cured yet so it just stuck to everything but was cured enough to make it a pita. Anyway. I got it clean and redid it all.
  #157
Old 08-31-2014, 10:07 PM
427 fordman's Avatar
427 fordman 427 fordman is online now
427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.427 fordman has a great reputation on FTE.
Looking good Nick! I've had a few of those moments where I wonder if I torqued something in a motor. It happens to everyone.
  #158
Old 09-02-2014, 12:01 AM
I made a bit more progress yesterday and today. The rockers are all in as well as the uvch's. I still have to incorporate the wiring from mine to the 9 pin system though.
I also got the vc's painted as well. I think it's looking pretty good. It should stand out a bit when I pop the hood.
What are you guys doing to connect the fuel lines from the motor to the frame. Are the factory quick disconnect fittings able to handle the pressure or should I go a different route?
  #159
Old 09-02-2014, 07:18 AM
DIYMechanic's Avatar
DIYMechanic DIYMechanic is offline
DIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to beholdDIYMechanic is a splendid one to behold
You'll be fine with the factory QD fittings. Actually, they're better at holding pressure than they are at holding a vacuum, so you're in good shape to use them with e-fuel.
  #160
Old 09-03-2014, 07:18 AM
man - that looks good when its all back together like that doesn't it?
i like the oil cooler paint. was your center tube rusty as anything? mine was, so i blasted it clean on the outside (having taped off the passage holes), then assembled it, then taped off the end cap passage holes, and painted the heck out of the hole thing with black engine paint. hopefully it holds up.
and i like your assembly method. i too don't have a press, and rubber mallet was getting me nowhere. a small section of 2x4 and a 5lb single jack hammer did the job for me, though :-)
  #161
Old 09-03-2014, 11:06 PM
Yeah I'm pretty happy with it JP. The oil cooler was pretty bad but the rebuild kit comes with a new one. I tried the mallet idea too with the same results then saw the strap on the floor, a light came on and done. I forgot to put a pic up with the vc's on the other day. It was pretty dark so it didn't turn out to well but you get the idea
  #162
Old 09-03-2014, 11:44 PM
Looks sharp!
  #163
Old 09-29-2014, 06:27 PM
Wow. It's been a long time since I got anything done on here. I've been hard at work with barn chores and getting the corn silage in the bunkers and grass baled and in and cover crops seeded. I did get a little bit done though. I've made the fuel lines and marked my up pipes for bellows. I'm going to try to get those accomplished tonight. I'll tack it all together then bring them to a friend of mine to be tig welded. We'll see how much time I have but if at all possible I'd like to start putting the wiring harness on and splice in the sd uvch's. I'll try to get some pics tonight
  #164
Old 09-30-2014, 12:16 AM
ReBilld's Avatar
ReBilld ReBilld is offline
ReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to beholdReBilld is a splendid one to behold
Looks GREAT Nick!! I like the black/red color combo.
  #165
Old 09-30-2014, 12:26 AM
I took some pics today.
Fuel lines. Done. I reused the the original feed and return lines up the block then went with 3/8" feed lines and 5/16" return on the top of the motor. Mainly just for ease. I realize it won't help with flow with the small ports on and out of the heads. I didn't want to go with rubber line for reasons I'm sure you all know about so I used steel lines and flared it. I hope it stands up to the vibration.
I got the exhaust manifolds blasted and painted and tacked the up pipes together. I'm going to take them in for welding though. I don't trust my welding for a task like this. I don't have much practice welding small stuff to big stuff and don't want to take a chance on something so hard to get at
I don't think I'm going to tackle the wiring harness tonight. I'm tired And Simpsons is on :P
Rebuilding a 390 need some advice on internals 99ARTaco 1973 - 1979 F-100 & Larger F-Series Trucks 11 01-17-2017 09:08 AM
engine rebuild kevintoupin 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-14-2016 11:33 PM
Can anyone match me on engine swaps? Red454sedgwick Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 4 12-26-2015 08:06 PM
machine shop tjg1964 1987 - 1996 F150 & Larger F-Series Trucks 7 09-08-2015 09:53 AM
1946 v8 239 rebuild kit c249a 1948 - 1956 F1, F100 & Larger F-Series Trucks 21 06-09-2015 07:11 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
