My first rebuild
#137
I have been trying to keep a watch on this overhaul because I am in the same boat Just dropped my block off at the machinest today. with .010 pistons from clay. I was curious what piston to cyl bore clearance is because I am seeing .0055 seems to be the recommended standard but my 94 7.3 DI ford service manual is calling for for .0036-.0048?? Just cusious what you did. Another question what did you go with for ring gap?? P.S. Sorry about the war wound!!
#138
I was thinking about this this morning. Having twins is as much of a curse as a blessing. All the milestones happen within a few days of each other. I'll only get to see one seventh birthday. There won't be another in 2 years. . Oh well. I'll still enjoy what I have
#140
#142
Do you mean inside by the timing gears. I'd have to take another look. I don't think so. If you have scoring there either something gone for a ride in there of your timing gears may have been walking. Were the thrust plate bolts on the cam tight.
#143
#144
No, sorry I should have explained different. Where the LPOP bolts to the timing cover. mine must have gotten trash in the oil. I am thinking of having .010" machined off to clean it up seems like that wouldn't hurt anything? She is in pretty rough shape for 124k miles.
#145
#147
True but it will just move the oil pump back the amount removed from the timing cover I think I will just look to see where the seal was riding on my harmonic balancer and if I have room on the sealing surface I'm going to go for it. I am pretty sure the engine would have to come back out to fix it later and I don't want to do that?
#148
K fellas. I made a bit more progress it today. Slapped a little paint on it
Then I thought to myself. Gee did I torque the oil pickup bolts??????? $#/+. So off with the pan and while at it I removed the front cover as well to get the one intake bolt in that is behind the hpop res. oh well. Could be worse. I could have put it together without torquing it and pooched my motor. For the record it was torqued.
I also got a bit creative with the oil cooler. I don't have the luxury of a press so I made do. It worked well
Yes that's a ratchet strap. And yes I used it to pull the peices together.
Rolled the motor over an started to put some stuff on top
I put the intakes on, the T-500, and got the injectors in. It was a good day.
#149
#150
