1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
loose wire
Old 05-06-2014, 02:24 PM
GLaJudice's Avatar
GLaJudice
GLaJudice is offline
loose wire
Hello,
I was out cleaning some corrosion off the battery terminals, and just below the battery i found a loose wire hanging free. It has a yellow clip that looks like it should go to a bolt for grounding or something. about 4 to 5 inches up from that yellow clip, there is a 60 amp inline fuse. Can anyone tell me what this is for and where to hook it back up to? I tried following the wire, but loose it somewhere under right side, passenger sidewall, almost like it whent to the fuel pump shut off. any help?
Glenn
Old 05-06-2014, 05:26 PM
acf6's Avatar
acf6
acf6 is offline
sounds aftermarket. may have had a amp/sub in your truck at some point and it was removed and the wire just cut and disconnected
Old 05-06-2014, 06:37 PM
r2millers's Avatar
r2millers
r2millers is offline
Agreed with aftermarket, maybe an old alarm system also.
Old 05-07-2014, 10:39 AM
GLaJudice's Avatar
GLaJudice
thanks for the replies, doesn't affect the the truck at all while running.
Old 05-07-2014, 02:10 PM
NorEasterMA's Avatar
NorEasterMA
NorEasterMA is offline
The 60A fuse sounds like it was a line for a speaker or subwoofer amplifier, I agree with everyone else it was something aftermarket that was cut out and just left dangling there.
Nigel Anderson
02-23-2016 11:24 PM
barljos13
01-17-2011 06:49 AM
MuDDoG2011
09-22-2004 09:18 AM
Marc150
02-03-2004 07:48 PM
chris_n_va
12-19-2002 03:50 AM
Quick Reply: loose wire
