3g Alt Swap Emergency!
I need help guys. Left the house at 3am for a field trip with my son's school, we're gone for 3 days. Limped my truck with a now bad 2g alternator to the school. I ordered a 130amp 3g 1 day shipping to my house. My wife will put it in my truck with tools to be waiting when we get back (we're ocean bound to Catalina Island). What tools and other equipment besides the alternator do I need to tell her to bring?
No signal at sea and we are about to leave, don't have time to search for a write up.
I have, a 94 F350 with a 7.5L, alternator has 8.25" ear spacing.
What do I need guys? Any help is appreciated. Would have checked out RJM but Ryan isn't in business I guess. Thanks.
Jeff
Jeff
Jeff
Jeff
Tell her to buy a new regulator plug for the 3g, 3-4 feet of 2 gauge cable, a 175 amp mega fuse and a holder for said fuse.
Fuse:
Napa part number:
BK 7821139
Holder:
BK 7821143
You will also need terminal ends, solder, a propane torch and heat shrink. The wiring is simple. Green wire from new regulator plug to green wire on old one. The other two are obvious. The 2 gauge cable goes from the post on the alternator to the fuse then to the starter relay on the fender.
Fuse:
Napa part number:
BK 7821139
Holder:
BK 7821143
Why are you trying to modify/upgrade in a time like this? You're away from home and relying on your wife to bring you tools that someone on the internet told you you'd need. Times like these you do what you can to get you home...not more modifications which opens up a huge possibility that your truck will be stranded in a parking lot a lot longer due to lack of tools and/or parts.
Just get a stock alternator, plug-n-play, and run it until you get home and can do the 3G swap at your own leisure.
hey guys just giving you an update. My dad was a total trooper and told my truck home from the school, and went to the junkyard and got me a 3Galternator wiring harness. If I'm not mistaken, I just hook it up straight, no need to splice wires if it was a factory harness from a 97, right?
the only thing I need to do is put the mega fuse in line with the battery charging cable I believe.
I've done it with a 92 but if your truck came stock with a 3g style alt then you should be able to plug n play. If I'm not mistaken though you would have the 2g 2 plug harness. I know that you do have to connect the green/red wire from the 3g plug to the green/red wire on the truck. On mine it was connected to the stock harness at one point and I cut the wire, took out the stock harness, and hooked the two g/r wires together. Then ran the battery cable from the alt to the starter solenoid and worked fine for me.
