2013 6.7 WHITE SMOKE
#46
#47
#49
So looks like the RAM side has finally started deletes on post 2013 trucks. User on another forum posted his cold start and there is a whif of white smoke as well.
Again, typically caused by a cold engine and rich startup conditions. Now if you had constant white smoke while driving around town, then I'd be concerned of an over-fueling situation.
#50
White smoke issue 6.7 powerstroke
Mine is deleted with H&S and I have noticed this problem. Out of curiosity:
What setting do you have your low boost fueling set at?
Do you have the defuel with cold coolant setting on?
White smoke - if it isn't coolant - as Sgt93 mentioned is due to incomplete combustion. There can be a lot of causes, failing glow plugs, too much fuel being injected, leaky injectors etc.
The following users liked this post:
