Why does it feel like my front axle is locked or welded? - Ford Truck Enthusiasts Forums
Old 05-05-2014, 03:22 PM
JMR JMR is offline
JMR is starting off with a positive reputation.
After some steering issues, I thought that it may be the steering column cause i know the bearing was bad. Got a new unit from a yard but didn't fix the issue.
Turns out the front axle (DANA 60) has issues..........Now what??
If I put it in four wheel, lock the hubs and jack up one wheel, i cannot turn the lifted wheel. I'm guessing it needs a new differential?? I'm not one to let others wrench on my trucks but this may be beyond my capabilities.....ouch..
Old 05-05-2014, 03:43 PM
mdh1701 mdh1701 is offline
mdh1701 is starting off with a positive reputation.
It is possible the differential is a locker, installed by the previous owner. However, if it only recently started doing this, and previously was fine, and you've owned the truck for awhile, it might be toast.
You should redo your test, except leave the t-case in 2wd so the front driveshaft can spin. With the t-case in 4wd, it SHOULDN'T turn with both hubs locked in, otherwise something would be wrong with your t-case. If it turns with the t-case in 2wd, the differential isn't the problem, keep looking. If it doesn't turn, either you have a locker or your diff is shot. After that, taking off the diff cover will tell you which. Good luck.
Old 05-05-2014, 03:50 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Quote:
That's exactly what's supposed to happen. Is this the only reason you think there's something wrong with it, or is there something else going on?
Old 05-05-2014, 04:08 PM
JMR JMR is offline
The steering is doing funky stuff the last week or so. yesterday I was going down a straightaway about 30 mph and it drifted a little, which is normal but when I went to correct I had to fight it to turn the wheel left from center. I can use the 4x4 and it does work but I suspect the differential part is bad.
Even today sitting still it took a some force to get it from center so disconnected the steering bar from pitman arm and from steering wheel to box is free so i dove in a little further, and found that the free wheel (off the ground) wouldn't turn
Old 05-05-2014, 04:11 PM
eakermeld's Avatar
eakermeld eakermeld is offline
eakermeld is gaining momentum as a positive member of FTE.eakermeld is gaining momentum as a positive member of FTE.
Brake caliper stuck?
Old 05-05-2014, 04:19 PM
JMR JMR is offline
Nope.. something further in...i've had many 67-72 f250 with dana 44 with no issues, this is my first truck (1995) F350 dana 60... not so impressed. Ive had it for a couple years and never had any problems with axle. I guess I'll pull the axle shafts tomorrow and see how it steers without them
Old 05-05-2014, 04:27 PM
eakermeld's Avatar
Does it steer OK with the hubs unlocked?
Old 05-05-2014, 04:43 PM
JMR JMR is offline
No, it has issues with hubs locked or unlocked... I almost have to assume it needs replaced. If thats the case, is it cheaper to put in a spool, locker or OEM diff?
Old 05-05-2014, 04:51 PM
eakermeld's Avatar
With the hubs unlocked, the differential is taken out of the equation. I would say you have a seized u-joint. They will give extreme resistance when steering and will even stop rotation of the axle when the hubs are locked.
Old 05-05-2014, 05:07 PM
JMR JMR is offline
with both front wheels touching the ground, the tcase in 2wd hubs unlocked, I should be able to reach in and touch the ujoint and axle and spin it freely, currently I cannot get to spin. This tells me that something in the differential part is wrong
Old 05-05-2014, 05:32 PM
eakermeld's Avatar
Both sides or just one?
Old 05-05-2014, 05:58 PM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Then pull the cover and look at what is going on
Old 05-05-2014, 06:36 PM
andym's Avatar
The Dana 60 is a highly sought after and VERY strong axle. Unless you are severely abusing the truck on a regular basis, or have monster tires on it, it's pretty well impossible to break it. U-joints, however, can seize up on any axle and it really sounds like this is what's happening. Pull the cover by all means, but my guess is that you're going to find nothing wrong.
Old 05-05-2014, 07:25 PM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
Sounds like dry ball joints to me but could also be a seized outer U-joint on the drive axle.
Old 05-05-2014, 08:33 PM
JMR JMR is offline
I think you guys may be right... when I stick my finger into the u joint (either side)and try to turn it was tight but then spun around almost a full revolution and then tight again. Trying to find a socket now for spindle nut, I have one with a sticker on it that says it will fit 1 ton but too small...Autozone don't have a clue how i can get one.
So as soo as I can get the right socket in my hand, I'll replace the ujoints and let u know. Thanks guys!!
steering wheel issues Aaron Hemingway 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 6 09-13-2015 09:00 PM
Help Diagnosing 4X4 Front Axle Trouble tjgalinski 1999 - 2003 7.3L Power Stroke Diesel 2 08-28-2015 09:42 AM
Can't turn key back to accessory and steering does not lock Daforno Nevada Chapter 2 08-23-2015 10:47 AM
2 axle u-joints on '89 F250??? Ford SD 1987 - 1996 F150 & Larger F-Series Trucks 12 03-31-2015 04:05 PM
New TSB to address 03 Expy LS Axle Differential Problem rahach 1997-2006 Expedition & Navigator 26 02-22-2004 09:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
