engine swap...best torque motor setup?
http://jastrauss.fastmail.fm/1990_p16.jpg
I just deleted a post that all but challenged the OP's sanity. Given what he wants, I think he should polish up his truck and drive it as is. Drive it with pride I might add.....
I like my 300. With a cam swap, it would be even better. I hate how it sounds though so I'm eventually going to pull it and put in something bigger. That's way down the line though.
I had a '95 F-150 with a stock 351W, E4OD, 3.55 gears and 33" tires. Definitely NOT geared for towing. I found it completely acceptable (although not at all exciting) moving a GCW of about 9,000 - 10,000 lbs (includes the truck weight). I've hauled the same load with an '02 PowerStroke and my '97 460. Both, although heavier trucks, would run away from the 351. Surprise, turbo-diesels and big-blocks make more power and torque than a small block! But of the three, I wish I still had the 351. It was all the power I ever needed and it had the lowest fuel cost of the three in normal driving.
on
I have seen over 17mpg at a steady 70mph cruise on level ground from my 5.8/AOD/3.55 combo.
on
Which don't mean squat unless you are driving from Houston to Beaumont every day of the year, and if that's a one-tank affair I doubt that it's accurate. I can get my 460 to get 15 mpg in that situation but it's not what I see driving it every day. Taking that number and saying, "My 460 gets 15 mpg" is not true.
That is for real highway gas milage from that combo, I used to do a lot of highway driving and it consistently got high teens. Around town though it consistently got about 13mpg which is about as good as one can expect from a 5000lb vehicle. Real people here with real numbers.. no funny business.
on
OK, Paul, you win.
Now I will start another fight - most of the 300 hype is just that: hype. I've owned both the 300 and the 302 (and put >150K on each) and I liked the 302 better. The 300 is a tractor motor, it does pull better off idle, but after that, it's a wash, except that the 300 makes very unhappy noises anywhere north of 2500 RPM. However, neither one of them is fit to carry my 460s jock strap in the torque department.
i was waiting for someone to say this, wasnt gonna talk up the 300 like i usually do becuase i cant figure out what the OP wants, one moment its low end torque the next its high rpm cams....
OK, Paul, you win.
OK, Paul, you win.
#28
Why not a simple 347 like was suggested earlier. Other than the increase in stroke, keep the rest as stock as possible. The Eagle kit is roughly $1,000 and you'd have (guessing here) 320-330lbs of torque?
I bet you you'd be very happy with that as a DD and occasional realistic-load towing.
gharmon
07-10-2001 04:47 PM
JAKKED4x4
06-04-2001 10:26 PM
