Upper and Lower ball joints - Ford Truck Enthusiasts Forums
Old 05-05-2014, 09:50 AM
bchez bchez is offline
bchez is starting off with a positive reputation.
Post Upper and Lower ball joints
I have a 2007 f-150 4X4 with bad upper ball joints, should I replace the lowers also or just the uppers and how do I check lowers? Thanks.
Old 05-05-2014, 10:19 AM
danorules's Avatar
danorules danorules is offline
danorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputationdanorules has a superb reputation
When my upper ball joint went bad I replaced upper and lower on both sides.I also upgraded to greaseable joints. My theory was I'm already dirty and if one went bad the others can't be too far behind. You will need a ball joint press to r&r the lower joints. Most auto part stores rent them. The upper are just new control arms, super easy to replace.
Old 05-06-2014, 10:33 PM
tbear853's Avatar
tbear853 tbear853 is offline
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Roll a floor jack under the lower control arm and jack until the tire is a few inches off the ground, now the lower ball joint is holding the spindle up. Insert long pry bar under tire and use it to lift the wheel tire spindle and you are looking for excessive play in that lower ball joint.
Alternatively, you can lay under the front with a jack under the LCA and place a finger against the spindle at the lower ball joint so you can feel if any movement as you or an assistant slowly jacks the LCA to transfer load on lower ball joint.
Old 05-07-2014, 02:07 AM
papasmurf40's Avatar
papasmurf40 papasmurf40 is offline
papasmurf40 is starting off with a positive reputation.
Like Dano said you are already dirty may as well do them all. I just did the uppers, lowers and inner and outer tie rod ends. like Dano said the uppers are super easy the lowers a bit of a pain but with a ball joint press it makes it bearable. Up in the Great white north here in Canada you can rent a ball joint press with all the adaptors, they charge you for the cost of it and refund the cost when you return the kit. as far as if you are going to replace the tie rod ends i would recommend doing inner and outers. FYI dont bother with the inner tie rod boots if yours look okay, but the factory steel band that holds the boot to the steering rack can be held with a thinner tie wrap. When you screw the inner and outer together and screw it into the steering rack on each side, before you remove ballpark a measurment of the total length of the assembly on each side from where it screws into the steering rack. Whether or not you do tie rods or not, DO get an alignment.
Ball joints sam hain 1997 - 2003 F150 3 01-01-2017 09:31 AM
ball joint removal, any ideas colin1966 1994.5 - 1997 7.3L Power Stroke Diesel 15 10-23-2016 08:36 PM
ball joints upper and lower mcsocal27 Ranger & B-Series 7 06-25-2011 08:44 AM
Ball Joints cost estimate bigtexan99 1999 - 2003 7.3L Power Stroke Diesel 12 09-28-2010 05:46 PM
Replacing upper +lower ball joints davdogg39 1978 - 1996 Big Bronco 5 04-12-2006 05:44 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
