Do not overtighten flare fittings, you are just pressing the soft flare against the seat. It should NEVER be tightened enough that the tube flare turns with the nut.
OK, sounds like I better check on all this before I get much further. If I have to replace the lines, I think it would be best to get shorter ones so they don't have to twist so much. Ya think? Tyler
Just make sure that you take into account the engine movement within the motor mounts and body flex.
