Rear end bent....I need a new one. - Ford Truck Enthusiasts Forums
Old 05-04-2014, 11:32 PM
maxtruck00 maxtruck00 is offline
maxtruck00 is starting off with a positive reputation.
I pull in my driveway this afternoon and I see gear oil running out the rear end of my truck.. So I put it up on the rack and find that the left side axel tube is coming out the the housing and appears bent? I'm not sure how this could have happened because this truck is used as if it were a Prius. I don't know if this is common or not, but I'm wondering if an aftermarket company makes something stronger? I don't want to buy a new "stock" housing just to have it fall apart again!
Truck is 2007 f150 4x4 5.4L 101k miles.
Old 05-04-2014, 11:52 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Based on my time here and the posts I've seen, I can say you are maybe the 3rd person with this problem who has posted here.
And the others were off-roading iirc.
IMO you can buy a used stocker and be fine. Of course, you should check the chassis for big rock marks, bashed jounce bumpers, broken springs and spring hangers etc etc. People do overload and overdrive, but most should be good.
Good luck with it.
Old 05-05-2014, 10:29 AM
jr105 jr105 is online now
jr105 is gaining momentum as a positive member of FTE.
Has you truck been jacked up under the pumpkin? I've never seen it, but some claim that jacking up the rear end by the pumpkin will cause this.
Old 05-06-2014, 08:00 PM
P.Bronner P.Bronner is offline
P.Bronner is gaining momentum as a positive member of FTE.
jr105 you get a gold star. Jacking up a truck by the diff. housing is the worst thing you can do. All that boss is supposed to carry is the weight of the housing. It doesn't even carry torque. Oh, I know guys have been getting away with it for ages, but if you look under a lot of older trucks you'll see them seeping gear lube around the axle bosses and that's exactly the reason why ( or SERIOUS off-roading). Typically they are pressed in and then secured with two spot/rosette welds. Its easy to overstress them by improper lifting, and I absolutely cringe at how many supposedly professional tire shops don't seem to know this.
Old 05-06-2014, 11:23 PM
tbear853's Avatar
tbear853 tbear853 is online now
tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.tbear853 has a very good reputation on FTE.
Quote:
...etc...
X2!
I can recall my dad getting irate at a tire shop once when the guy started to jack the rear of the car like that to swap on snow tires in the early 60s ..... never forgot it. The guy stopped too.
I recall many times over the years telling guys not to do that or let someone do it to their car, and here on the internet guys will come back and tell you that you are wrong .... but you are so right.
Anyone who doubts it hasn't looked at the weight of the vehicle and the long leverage provided by the axle tubes and the short "insert" length that they are pressed into. You can make it some stronger by welding a good bead around the tubes where they enter the center .... best done with rear apart out of vehicle with no oil in it and then a good check for straightness is in order.
Old 02-13-2016, 03:32 PM
82_F100_300Six's Avatar
82_F100_300Six 82_F100_300Six is online now
82_F100_300Six has a good reputation on FTE.82_F100_300Six has a good reputation on FTE.
I have to say I learned something today I've been doing it wrong for years. I have a new truck and I'm glad I saw this
Is it okay to :
Both wheels off ground and jackstand on each side under tube between diff and leaf spring pad?
And jack up one wheel under the leaf spring pad?
Old 02-14-2016, 12:21 PM
tbear853's Avatar
The closer the jack & jack stands are placed to the spring pad or wheel, the better. One jack in center places an enormous load on the rear axle picking up the weight of the vehicle out at the ends .... think of "leverage". Placing the jack just half way between the center and the spring will cut the leverage factor at that joint of axle tube-center to fully half.
Old 02-14-2016, 01:22 PM
brokenleg brokenleg is online now
brokenleg has a good reputation on FTE.brokenleg has a good reputation on FTE.
I learned something new. Glad I read this.
Old 02-14-2016, 06:51 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Check out Car-Part.com--Used Auto Parts Market. It's a salvage yard database, and you can search for a used axle and compare prices by location.
1977 Camper Special Bent PS Pulley Trilogy81 1973 - 1979 F-100 & Larger F-Series Trucks 7 05-25-2016 09:17 AM
How to straighten a bent hinge post? chintonmd 1997 - 2003 F150 1 04-01-2016 10:01 AM
What's the name for the bracket that goes from RJNRJN 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 03-15-2015 06:35 PM
Turbo shaft play- time for rebuild? paddler 1994.5 - 1997 7.3L Power Stroke Diesel 4 12-29-2012 11:35 PM
Are they kidding me !?! ItsET 2004 - 2008 F150 26 06-13-2010 04:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
