Things I've learned from my truck.
Seems like I've learned all kinds of things since I've gotten my 48. For example:
* Floor pans can be patched with road signs. - I had no idea, until I crawled under my pickup and saw "ROAD WORK" staring me in the face. (Ok, I"m assuming it's road work. All I really see is "AO OR")
* Body filler needs no shaping or sanding. - I have to admit, I was intimidated by the idea of trying to do any body work, but after seeing what's already been done on my truck, patching must be easy. Just slop it on and stand back. PERFECT.
And todays lesson:
* If it doesn't fit, just wrap in masking tape until it (sorta) does.
And todays lesson:
I learned that a gallon of Bondo, no matter how thick it is applied, doesn't really stop or fix the rusted out area around the two part front fender seam. Also that having a piece of angle iron as a transmission cross member, with one bolt to the bottom of the trans and no other fastener of any kind is not the correct way to do it (it was just resting on top of the frame rail). Also that having a steel bar bolted to the front of engine and welded to the frame with NO rubber anywhere doesn't make the best motor mount.
Now come on be honest . How many of those things actually worked ? There is a old saying [ it is only cob when it doesn't work ] . I would like to have a $ for every car or truck running the roads with road sign floors . Or spray foam to fill cab corners ,1/4 panels, and door bottoms . To be honest I have done this type of thing in the past , And so have most of you . I even painter a truck with porch and deck enamel ,when I had little $ and needed to get it one color . Road signs have saved my feet and legs from falling through the floors on a few junk cars and trucks , when I could barely pay the rent . Then there is the learning curve , the older you get the better you get .
I have replaced some of the wire nuts, and put electrical tape on the rest. I spray painted the orange wire black under the flatbed so it didn't look so stupid.
