l&l - Ford Truck Enthusiasts Forums
l&l
Old 05-04-2014, 07:15 PM
lafermedavid lafermedavid is online now
lafermedavid is gaining momentum as a positive member of FTE.lafermedavid is gaining momentum as a positive member of FTE.
l&l
im getting ready to order the 460 highboy kit from l&l,sorta struggling deciding with exhust hidden in frame or exhaust running on outside of frame.I will be using the borgenson shaft with a 4" lift,,,,dont want any hassels with my steering shaft,,,,what do you all think?before I finalize thanks in advance for all input,I value also running 37 x 12.5 rubbing factor?
Old 05-04-2014, 10:00 PM
kwe45919's Avatar
kwe45919 kwe45919 is offline
kwe45919 is starting off with a positive reputation.
If the truck is lifted, I think it's cool to have the exhaust tucked into the frame. Makes it look cleaner.
Old 05-04-2014, 10:37 PM
I know what you mean.sorta feel the same way,but it would sure make things easier on exterior,,,anybody have any pics?
Old 05-04-2014, 11:41 PM
blue04.5's Avatar
blue04.5 blue04.5 is offline
blue04.5 is gaining momentum as a positive member of FTE.blue04.5 is gaining momentum as a positive member of FTE.
I don't know if this is what you are looking for exactly but here is some inside frame shots.
http://www.ford-trucks.com/forums/11...l#post13470652
Old 05-05-2014, 07:29 AM
PA F250's Avatar
PA F250 PA F250 is offline
PA F250 is starting off with a positive reputation.
I have the L&L outside frame headers (460, f250, 6" lift, 4x4). Haven't finished the exhaust yet but it's basically a straight shot down the frame and dump in front of the rear tires. With a couple bends, I'm hoping to be able to tuck it up close the the bottom of the cab so it isn't as noticeable. Outside saves a bunch of hassle and expense on the exhaust. Also clears up the starter area on the pass side and clutch linkage, brake proportioning valve, fuel lines etc. on the drivers side. I have the Borgeson also and not interference issues. Did have some "fitting" to do at the front cab corner supports to let the headers clear.
Old 05-05-2014, 10:31 AM
scooter79's Avatar
scooter79 scooter79 is offline
scooter79 is starting off with a positive reputation.
I used the fender well headers on my 79. They did hit the cab mount on frame, I have a 1 1/4 custom body lift. the exhaust was super simple. One offset bend to keep muffler high and out of sight. supper 40's and "pypes exhaust " dumps.
Old 05-05-2014, 02:45 PM
Thanks Guys for your input.PA250 any chance when you get around to it you canpost some pics of your exhaust,Im sure that would be helpful for some others contemplating.Shoot you might have not got there quite yet.Thanks
Old 05-06-2014, 07:52 AM
PA F250's Avatar
I don't have it totally done yet but lots of pictures along the way that will give you the right idea. I have 18" Magnaflow mufflers on there now. Once I get to the exhaust I have a 4' section of SS to go from the collector to the muffler and then a 2' piece to bend at 45 or so to dump in front of the rear wheel.
Old 05-06-2014, 09:01 AM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Awesome shots PA250 thank you for the detail.
lafermedavid here is an idea of what inside the frame will get you. Along with a free headache and a exhaust guy that hates you.
Yes one pic is a 2wd, but you get my point about the cross member right?
Fenderwell exit headers make life more better and finishing the exhaust is way easier and can ever be completed by yourself.
The last 2 pics show it like it is, fenderwell exit headers, straight pipe, chrome tips and wire pipe hangers. (look at that quality double wire lacing and x pattern) lol
Old 05-06-2014, 02:34 PM
Thanks Rich
Old 05-06-2014, 03:20 PM
turbohunter's Avatar
turbohunter turbohunter is online now
turbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant futureturbohunter has a brilliant future
Hey PA F250
What's up with all the holes in your frame?
Sorry for the mini hijack.
Old 05-06-2014, 04:25 PM
PA F250's Avatar
Are you referring to the ones up front by the shock towers etc.? Those are access holes for mice to build homes in.
Seriously though, I wouldn't know they shouldn't be there. This is my first truck of this model and first rebuild. I bought the restoration project from another guy after he had already done the frame. I think it started life as a 2wd so maybe something to do with that. Something I should be fixing? Especially since I just got it painted and all. lol.
Old 05-06-2014, 04:31 PM
61steven's Avatar
61steven 61steven is offline
61steven is starting off with a positive reputation.
I have to say that stainless fender well exit headers look pretty darn good to me!
77&79- Did you notice a difference after putting on the X-pipe? I have read that some engines(low end torque) don't respond well to them.
Old 05-06-2014, 04:40 PM
Strong mice
Hey it's running and it works.
It just surprised me as I just finished a front end install and it's quite a bit different.
Interesting that they are behind the tower on one side and in front on the other.
I'm sure it's fine.
Easy on the jumps though.
Hijack over.
Old 05-06-2014, 05:01 PM
77&79F250's Avatar
Used OEM parts guy
Those holes are common F250 front end access, I do believe, all 4 of mine have them....
The 1st pic I attached has them too.
X pipe was only a pic I saved to show inside the frame exit headers and crossmember issues, its not mine.
Replace balance shaft chain tensioner w/o pulling motor? Space Truckin' Explorer, Sport Trac, Mountaineer & Aviator 9 07-29-2016 06:59 AM
2004 Drive Shaft Carrier Bearing Bracket vlietracer64 1999 to 2016 Super Duty 5 03-29-2016 08:13 PM
F350 drive shaft John Ken Howerton 1987 - 1996 F150 & Larger F-Series Trucks 5 03-08-2016 12:07 PM
drivers side oil leak 62uni4x4 1994.5 - 1997 7.3L Power Stroke Diesel 29 12-23-2012 10:07 AM
78 4x4 Headers Inside of Front Drive Shaft. bigblue 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-03-2005 12:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
