l&l
Old 05-06-2014, 04:08 PM
turbohunter's Avatar
turbohunter
turbohunter is offline
Those holes are common F250 front end access, I do believe, all 4 of mine have them....
Man I've gotta get a 250 so I know this shtuff.
Old 05-06-2014, 04:19 PM
77&79F250's Avatar
77&79F250
77&79F250 is offline
Moderator & parts seller
Received 3,286 Likes on 2,442 Posts
Going to go ck all 4 and take some pics for you. BRB
Old 05-06-2014, 04:53 PM
77&79F250's Avatar
77&79F250
Well I cked all 4 trucks and the frame rig (5th) and they all have the same holes that allow you access to the bolts that hold down some frame top plates/brake line clamps, and to get to the front motor perch hdrw on both sides, and the bump stop. And yes nice place for the mice to access the frame to build a home, the littel fuzzy chits.
In order of pics
1. L/H 79 ol red D44
2. R/H 79 ol red D44
3. R/H 79 ol red D44
(4) L/H silver 77.5 D44 (w/leaking steering box)
(5) R/H blue 78 D44
(6) R/H maroon parts truck D60
(7,8) L/H-R/H frame rig D60
FYI the cobbed up stuff (front spring perch drop, shock drop bracket and brake line BS) you see on the frame rig is thanks to the dumb a.. PO.
Old 05-06-2014, 05:19 PM
turbohunter
Cool, thanks Rich.
And sincerely apologise about the hijack.
Old 05-06-2014, 05:59 PM
lafermedavid's Avatar
lafermedavid
lafermedavid is offline
Thanks PA250 nice rig.Great Pics; really gives detail to the application.My 75 doesnt have the holes.
Old 05-06-2014, 06:17 PM
lafermedavid
Hey WW is that a Bersa in your avatar?
Old 05-06-2014, 06:27 PM
grinnergetter's Avatar
grinnergetter
grinnergetter is offline
If your L&L's hit your cab perches you need L&L engine perches as well. They claimed that they lowered the engine a smidge for header clearance.
I know, I know....but that's the info they gave me.
Old 05-06-2014, 06:31 PM
turbohunter
Hmm
Thanks Grinner
I hadn't thought about that.
That mod might clear up a couple of problems on my rig.
Something to ponder.
Old 05-06-2014, 06:43 PM
lafermedavid
Wow good info Grinner,my truck already has a 4inch lift.I just wasnt into raising the cab even higher for clearance.Thanks Guys.Look familiar Grinner
Old 05-06-2014, 07:42 PM
bucks77ford's Avatar
bucks77ford
bucks77ford is offline
I also like the clean look of the chassis exits. There is plenty if clearance for the exhaust running down the chassis and really no issues with the crossmembers. It's a little tight going by the T-case, but I don't have any issues with mine. I have also been able to take the headers on and off with no problem.
Old 05-06-2014, 08:11 PM
lafermedavid
Heres a question concerning fender well exits.Can you still use your plastic Mud skirts inside your fender well opening?Or will they melt them.
Old 05-06-2014, 09:06 PM
77&79F250's Avatar
77&79F250
My red truck with fenderwell exits did not have them, so I just has to trim a little of the metal inner fenderwell.
  #28
Old 05-07-2014, 08:58 AM
PA F250's Avatar
PA F250
PA F250 is offline
Wow, I missed a bunch of activity on this post. Glad to hear I don't need to worry about patching up a bunch of holes.
L&L Motor mounts - I thought I read on their site that they claim to locate the engine in the stock position. When I used them, I found that the clutch linkage Z-bar no longer sat level (must have lowered the . I made a thread about knocking out the engine side post and relocating it to level out the Z-bar.
For the fender exit headers, yes, you do need to trim the inner fenders (especially if you don't have a body lift). I am planning to try a used set of plastic liners which will probably need trimmed also. If the melt and warp, I'll take them out.
  #29
Old 05-07-2014, 11:35 AM
lafermedavid
Thanks PA250,I remember you off seting your linkage.Ill be into that soon enough
RedFive_R5
WTB - Parts & other
02-21-2018 08:31 AM
Samsn4
09-28-2012 09:29 PM
BrizNasty
08-12-2011 11:50 PM
Ashley_underground
Exhaust Systems
05-19-2011 07:52 PM
randrford
11-21-2009 09:41 PM
Quick Reply: l&l
