Fuel bowl re - O ring? - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 05-04-2014, 06:41 PM
5280's Avatar
5280 5280 is offline
5280 is gaining momentum as a positive member of FTE.
I have a fuel leak on my 2000 Ex, 7.3l. I'm guessing it is at the fuel bowl. I replaced the drain valve o-rings about 5 years ago. Would you guys suggest I purchase a kit to replace all of the fuel bowl o rings and seals or just do the drain valve o ring again? The truck has 210k miles on it.
Old 05-04-2014, 07:28 PM
Pikachu's Avatar
Pikachu Pikachu is offline
Pikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud ofPikachu has much to be proud of
It's usually just the drain valve that leaks, but it certainly wouldn't hurt to change all of the o-rings. It isn't a hard or particularly time consuming job anyhow. If it is indeed the valve, you might be able to stop it temporarily by snugging up the four torx screws that hold it on.
Old 05-04-2014, 07:36 PM
A/Ox4's Avatar
A/Ox4 A/Ox4 is offline
9 ECHO 1
A/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputationA/Ox4 has a superb reputation
Everything our little electric friend said above me is true. Its usually the drain valve, but I would do the whole thing, time permitting.
Old 05-04-2014, 07:54 PM
5280's Avatar
Thanks guys. I will order the bowl rebuild kit and take it from there. If I remember correctly, it was a fairly simple job to do the drain valve o-rings. I'm sure doing the rest of them won't be a big deal. Last time I had to do them it was in the middle of the winter, no garage. At least the weather is more agreeable now
Old 05-04-2014, 10:00 PM
A/Ox4's Avatar
9 ECHO 1
Quote:
I've got a video outlining it on YouTube of you find that will make it easier.
Old 05-04-2014, 10:30 PM
5280's Avatar
Quote:
Thanks for the heads up on your videos. I will check them out.
diesel fuel in the valley bdave 1999 - 2003 7.3L Power Stroke Diesel 4 11-12-2016 07:35 PM
blocking off fuel bowl drain? cedman 1999 - 2003 7.3L Power Stroke Diesel 16 10-29-2015 02:48 AM
guzzle's Diesel O-rings ron's power stroke 1999 - 2003 7.3L Power Stroke Diesel 20 12-08-2011 03:11 PM
Fuel Bowl Plug O-ring's Bigcat350 1999 - 2003 7.3L Power Stroke Diesel 6 12-27-2009 09:19 AM
Fuel bowl drain valve 5280 1999 - 2003 7.3L Power Stroke Diesel 2 11-21-2009 07:58 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
