random misfire cyl 1/3/4 rough idle - Ford Truck Enthusiasts Forums
Old 05-04-2014, 06:09 PM
buckem88 buckem88 is offline
buckem88 is starting off with a positive reputation.
Ok so I have the 2009 f150 4.6l 2wd. Have random misfire codes. Horrid idle. I replaced all of the spark plugs, coil packs, and even the injectors on 1/3/4. Still codes nothing is better. I'm thinking maybe an intake manifold leak,? I see no real signs but I do hear that little pop pop pop. Now I have a gasket kit for it but I see you can order complete manifold kits with thermostat and gaskets on amazon for like 60 bucks more. The issue is I see none that fit my truck. Is it the same as the mustang? Hate to blow more cash as its adding up. Anything else it could be?
Have codes 301 303 304
Old 05-05-2014, 04:40 PM
je5 je5 is offline
je5 is starting off with a positive reputation.
I believe manifold is different than Mustang. Did you use Motorcraft coils?
Old 05-05-2014, 05:14 PM
Yeah I ordered all parts from ford parts. So all is motorcraft. This issue has me baffled. Tried the carb cleaner around manifold as well no difference...
Old 05-05-2014, 06:49 PM
je5 je5 is offline
"Anything else it could be? "
Did you check the PCV hose for a vacuum leak?
Old 05-09-2014, 01:36 PM
Thanks for info. I changed intake gasket it wAs damaged and helped a lot. But still had issues with cyl 3 1 and 4 cleared up. Turns out to be cyl 3 had blown a plug 8 months ago well the insert and plughave melted and I need a new head. (Yes same week old plug) Of course I have the stupid motor nobody makes parts for so a new head at ford is 1400. Or i get a complete crate rebuilt engine for 2900 through ford. As im up to 140k and have a brand new tranny and rear end I think I just might opt for the new engine. They claim they have updated heads that dont have the blown plug issue.... we will see. Thanks for the help!
Old 05-09-2014, 01:45 PM
je5 je5 is offline
Smile Aluminum Heads need Al Inserts
Yes I would go for the engine with a warranty.
Steel inserts in an aluminum head do not work well because of the heat transfer, it needs an aluminum insert. Lock n Stitch is now the Ford approved method.
Old 05-09-2014, 08:52 PM
Cool good to know. Yeah warranty would be great. I knew the insert needed to be aluminum but I was in the middle of bfe on a work trip when it blew. I was just happy to have it fixed and get home.... so my bandaid worked 8 months. And I forgot all about it. I guess I cant complain...
Old 05-10-2014, 02:08 AM
je5 je5 is offline
At least most of the parts you bought will transfer over to the new engine.
Hope it goes well and welcome to FTE.
'98 Expedition 4.6 Random Misfire ctown2 Expedition & Navigator 44 06-24-2016 09:09 PM
04 Escape Misfire and I've Tried Everything I Can Think Of payntertk31 Escape & Escape Hybrid 15 10-05-2015 05:43 PM
random misfires on cyl 1, 3, 4... very rough idle. 2009 f150 buckem88 2009 - 2014 F150 4 05-10-2014 06:32 AM
99v10 Something is wrong PLEASE advice Mathew99v10 1999 to 2016 Super Duty 64 06-28-2011 05:13 PM
1999 4.6 misfire edford1 Modular V8 (4.6L, 5.4L) 0 09-17-2010 08:32 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
