random misfires on cyl 1, 3, 4... very rough idle. 2009 f150 - Ford Truck Enthusiasts Forums
Old 05-04-2014, 03:43 PM
buckem88 buckem88 is offline
buckem88 is starting off with a positive reputation.
Ok so I have the 2009 f150 4.6l 2wd. Have random misfire codes. Horrid idle. I replaced all of the spark plugs, coil packs, and even the injectors on 1/3/4. Still codes nothing is better. I'm thinking maybe an intake manifold leak,? I see no real signs but I do hear that little pop pop pop. Now I have a gasket kit for it but I see you can order complete manifold kits with thermostat and gaskets on amazon for like 60 bucks more. The issue is I see none that fit my truck. Is it the same as the mustang? Hate to blow more cash as its adding up. Anything else it could be? Sorry if there are typos on a tablet. Thanks
Old 05-05-2014, 01:48 PM
DIP51 DIP51 is offline
DIP51 is starting off with a positive reputation.
Spray carb cleaner around the intake manifold and see if it idles better. If it doesn't, it probably isn't the issue.
Old 05-05-2014, 07:16 PM
fastback89 fastback89 is offline
fastback89 is starting off with a positive reputation.
Did you check compression?
Also, use a noid light to see if PCM is firing injectors and coils...
Old 05-09-2014, 12:33 PM
Thanks for info. I changed intake gasket it wAs damaged and helped a lot. But still had issues with cyl 3 1 and 4 cleared up. Turns out to be cyl 3 had blown a plug 8 months ago well the insert and plughave melted and I need a new head. Of course I have the stupid motor nobody makes parts for so a new head at ford is 1400. Or i get a complete crate rebuilt engine for 2900 through ford. As im up to 140k and have a brand new tranny and rear end I think I just might opt for the new engine. They claim they have updated heads that dont have the blown plug issue.... we will see. Thanks for the help!
Old 05-10-2014, 05:32 AM
tseekins's Avatar
tseekins tseekins is offline
tseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputationtseekins has a superb reputation
Seems to me that smart says, get the new engine if you plan to keep the truck.
Misfire and generally running like crap BrentD22 1997 - 2003 F150 4 01-27-2017 12:07 AM
5.4 randomly misfiring C&W Auto and Diesel 2004 - 2008 F150 29 10-17-2016 08:30 PM
04 Escape Misfire and I've Tried Everything I Can Think Of payntertk31 Escape & Escape Hybrid 15 10-05-2015 04:43 PM
random misfire cyl 1/3/4 rough idle buckem88 Modular V8 (4.6L, 5.4L) 7 05-10-2014 01:08 AM
2005 f150 rough idle and loss of power Spudy 2004 - 2008 F150 1 02-10-2014 12:27 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
