"Limp Mode" Question. - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Old 05-04-2014, 02:57 PM
Tawn's Avatar
Tawn Tawn is offline
Tawn is gaining momentum as a positive member of FTE.Tawn is gaining momentum as a positive member of FTE.
I hear about you guys talk about your trucks going into limp mode. Late last week while I have been dealing with HFCM issues my truck basically stopped making normal power.
The engine still revs and the turbos are creating boost but the truck will hardly get out of it's own way. Is this "limp mode"? It doesn't make sense to me if it is limp mode, why the engine will still make up to ~2200 RPMs (that is all the harder I pushed it). I would think the limp mode would limit the engine RPMS lower than that.
It is a bone stock 08 with 84K on it.
Thanks for the help.
Tawn
Old 05-04-2014, 05:22 PM
senix's Avatar
senix senix is online now
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
You are in limp mode. Yes you can get about 2200 rpms but very slow to take off and gain speed. Speed is also only about 50 going downhill with a tail wind.
Old 05-04-2014, 05:39 PM
Tawn's Avatar
Quote:
Thanks for the info Senix.
Old 07-31-2014, 01:52 PM
HighOctane's Avatar
HighOctane HighOctane is offline
PMS: an obsession
HighOctane has a very good reputation on FTE.HighOctane has a very good reputation on FTE.HighOctane has a very good reputation on FTE.HighOctane has a very good reputation on FTE.
This just happened with my F-550. It turns out the EGT sensor is bad and puts the truck in limp mode, not throttle response. $480.00 later.
Old 08-02-2014, 07:03 PM
acstokes acstokes is offline
acstokes is starting off with a positive reputation.
My 2009 F-250 6.4 is sometimes sluggish for 1-2 minutes after first started before the engine starts to warm up. The engine revs up, but there's little acceleration. No dash lights come on. Does this sound like limp mode?
Unverified trouble codes Maathiu Ra Yin Electrical Systems/Wiring 1 10-18-2016 09:37 AM
E4od limp mode but no codes plowboycowboy Clutch, Transmission, Differential, Axle & Transfer Case 9 07-20-2015 07:44 PM
limp mode no check engine light jagodog 6.4L Power Stroke Diesel 1 05-16-2013 08:40 PM
ABS light on 94 idi turbo franklee86 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 5 01-28-2013 08:55 PM
"limp" mode Texas450 6.4L Power Stroke Diesel 14 11-11-2010 07:04 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
