1949 ford f1 clutch problems - Page 2 - Ford Truck Enthusiasts Forums
Old 05-04-2014, 05:35 PM
cradduckj cradduckj is offline
cradduckj is starting off with a positive reputation.
here is a picture looking inside the inspection hole and you can see when the throwout bearing moves it's 1" of travel it will just make it to the fingers.
Old 05-04-2014, 06:08 PM
ALBUQ F-1's Avatar
ALBUQ F-1 ALBUQ F-1 is offline
postin' fool
ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.ALBUQ F-1 has a spectacular reputation.
Have you adjusted the clevis at all?
Old 05-05-2014, 07:03 AM
49willard 49willard is offline
49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.49willard has a great reputation on FTE.
Quote:
Originally Posted by ALBUQ F-1 View Post
So you have a Light Duty 3-sp, if the trans has half of the bellhousing cast as part of the trans case.
Have you tried adjusting the clutch linkage? At the clevis inside the frame rail?
Did you remove the cross-shaft and fork as part of the rebuild? Any chance the fork is in backwards?
Ross,
I guess that it has been too long since I do not remember doing anything unusual when I changed Willard from the original light duty 3 speed to the HD 3 speed. My memory was that it was a stock bolt in using the same clutch and driveshaft. Willard was running a 56 Buick Nailhead back then (the reason for the change to the HD 3 speed).
I think that I did it in 1978 so memory is probably a problem!
1949 Ford F1 rear end ratios millerliteliker 1948 - 1956 F1, F100 & Larger F-Series Trucks 27 07-15-2016 06:34 PM
1949 f1 to f3 Frame difference brooksdw 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 12-01-2015 02:02 AM
carb for 1949 ford f1 6 cyl frenchyo 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 04-29-2015 12:11 PM
Wanted, 1949 Ford F1 Transmission Cover Vegas123 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 04-28-2015 02:10 PM
Mounting clutch pedal assembly Trussonistephen 1948 - 1956 F1, F100 & Larger F-Series Trucks 3 12-22-2014 10:32 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
