Enhancing mpg on a 460 - Page 2 - Ford Truck Enthusiasts Forums
Old 05-05-2014, 02:01 PM
Gary Lewis's Avatar
Gary Lewis Gary Lewis is online now
Gary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant futureGary Lewis has a brilliant future
My memory is quite vague on the price of petrol. This site says the price in the States was about $1.10/gallon, and I remember thinking I was paying the same for a liter in the UK as folks were paying for a gallon in the US. If that's true I was paying about $4.25/US gallon in 87/88.
Old 05-05-2014, 03:19 PM
ctubutis's Avatar
ctubutis ctubutis is offline
ctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputationctubutis has a superb reputation
Who is Tricky Dick? I think of Richard Nixon, who preceded Gerry Ford, who preceded Jimmy Carter, the peanut farmer from Georgia whose administration I remember having implemented that.....
Old 05-05-2014, 03:22 PM
Gary Lewis's Avatar
Yup. That's the one. Richard Milhous Nixon. Interesting. Spell check can't spell Milhous. I know how to spell it because that was our dog's name. Fitting - he ran off one night.
Old 05-05-2014, 03:48 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Tax on fuel accounts for most of the disparity. Hopefully nobody is suggesting that confiscatory gas tax rates are good for anybody. Although, it costs a bunch for a carrier group so it's gonna show up somewhere. Probably inflation and higher ... taxes. Hm.
Anyway, one thing to look at with the big V8s is engine tuning - timing and advance, weights and springs, and vacuum advance. This will add tremendous percentage gains at least, compared to a poorly tuned motor.
Racing motors are setup and optimized for wide open throttle, not for economy. Careful tuning will at least get the most of what is technically feasible.
Sent from my iPhone using IB AutoGroup
Old 05-05-2014, 04:05 PM
mdh1701 mdh1701 is offline
mdh1701 is starting off with a positive reputation.
You didn't mention whether you had auto or stick. Converting to OD with an auto will get involved and spendy. Converting a stick will cost you parts and a couple hours of your time. City MPG will be crappy regardless, hwy MPG will improve a bit, but don't expect to see the high side of 12MPG no matter what you do. In fact 12 would be optimistic on a 4x4...
A pre-smog timing set and an advance kit for the dizzy, along with setting the base timing to 12 degrees BTDC will help with performance, but take it easy on the gas and it can help MPG a little... probably not enough to be much help, but a little. You would have to do other things to see any significant improvement, but you'll never see a return on your investment.
Or basically what everyone else has said! (great minds think alike...)
Old 05-05-2014, 08:04 PM
cajohnson cajohnson is offline
cajohnson is starting off with a positive reputation.
Quote:
Originally Posted by mdh1701 View Post
A pre-smog timing set and an advance kit for the dizzy. . .
I've read other references like this, but what does it mean? (Long time driver, but short time owner. . .)
Old 05-05-2014, 08:32 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
They use a timing chain and sprockets from a old 429 I believe. This changes the valve timing to a more favorable setting.
There can be gains from playing with the distributor, but a Ford dist is a real pain to play with. If you were serious about doing this, I think I would put a MSD setup, dist and all, where you can more easily mess with the springs and weights. It's not cheap though.
Old 05-05-2014, 08:37 PM
Thanks for the info!
Not to hijack the thread, but I'm putting the EDIS ignition and MegaJolt on my engine. Lock down the distributor, and then it's time for some fun! I'm at about 9000' in elevation and the MegaJolt will make it much easier to find the right timing.
Old 05-05-2014, 09:34 PM
beetle beetle is offline
beetle is starting off with a positive reputation.
6.5 power valve, cheap and easy.
Mpg? Truck Guy99 1987 - 1996 F150 & Larger F-Series Trucks 29 05-08-2014 11:09 AM
1996 f250 4x4 460 fuel milage lawmanpinto Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 6 02-16-2012 06:42 PM
Discuss 460 mpg efficiency. 1800joedaddy 1987 - 1996 F150 & Larger F-Series Trucks 33 02-06-2012 09:52 PM
460 efi mpg what you getting powerstroker100 1987 - 1996 F150 & Larger F-Series Trucks 17 01-01-2011 09:02 PM
What is the highest MPG heard of in a 460 74crwcb429hibPS4spd Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 50 03-11-2003 07:53 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
