po 1131 & 1151 on a 99/00 e250 w/5.4 - Ford Truck Enthusiasts Forums
Old 05-04-2014, 01:42 PM
thosfsull thosfsull is offline
thosfsull is starting off with a positive reputation.
This is our oldest van with us for about 11 years or so. It is a 99/00 e250 extended with roughly 165k on it. It was sucking down fuel like no tomorrow and I brought it to my friend's body shop. He cleaned the MAP sensor with spray and the fuel curve went back to normal for about a month.
Sent 2 guys to fix lights at a gym across the river in the city and the truck went insane. Didn't want to idle and kept stalling. Act of God to get it back to my house and had the worker switch trucks.
Turned the truck over and it won't run for a second. Immediately stalls, if you gasd it and try to get it in gear it shakes and konks out. Has a service engine light on, so i borrowed my friend's snap on scanner with the ford key chip and ran for codes. Got two with them being 1131 and 1151.
Anyhow I was looking all over and it says a few different things. Is there anything simple I can do to rule out before I call the towtruck or steal back my towdolley and get it brought to my friend's garage? So I will most likely wait till tomorrow.
Getting towed cheap or at all on a Sunday is an act of God. I know anything with a doghouse van set up is a triple joy to work on.
Old 05-04-2014, 02:27 PM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Look for a massive vacuum leak, either in the PCV valve plumbing or in the intake tubing
1999 V10 running rough p1131 p1151 oachs83 1999 to 2016 Super Duty 1 10-13-2016 06:21 PM
Excursion having some idle issues. ROBBINthaHOOD Excursion - King of SUVs 8 05-23-2016 12:24 PM
Help! Codes P0136, P1131 and P1151 Denver Davis Electrical Systems/Wiring 7 02-13-2016 08:37 PM
"service engine soon" light on after pulling spark plugs jbourne84 1968-2013 Full Size Vans 3 02-02-2016 08:06 AM
Isolator bolts and misfire cyl. 5? .. (P0420, P1131, P1151, P0171, P0174, P0316, and P0305) Im50fast 3.8 & 4.2L V6 7 11-13-2013 12:31 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
