Intercooler Install OBS Ford (Pic heavy) - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 08-06-2014, 11:31 PM
Chris56ford's Avatar
Chris56ford Chris56ford is offline
lost
Chris56ford is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by LeoJr View Post
Chris, thanks for all the pictures! Do you have any pics of your modified hood latch?
And another question (I know, I'm getting greedy) about the bottom support brackets you made… Your solution seems to be similar to most others that I've seen, but it requires welding. The angle piece you used basically is welded to the inside edge of the square tube. How long would that bottom leg of the angle have to be to come flush to the far edge, closest to the bumper? Here's my idea, use a piece of angle that is thicker and bigger, your dimension will tell me how big it has to be. I cut a piece of paper because it was easier that describing my thought…I think 1/4" thick angle would be sufficient. Your thoughts?
Your welcome. I will try and get some pics of the hood latch for you. Some guys just cut the strap and leave it off, which I think would work fine, it doesn't support much I don't think. I just welded a piece of strap iron to the latch plate.
I think your idea for the brackets would work fine as long as it is thick enough, like you said a 1/4 or more. I'll get some measurements for you as well.
Old 08-06-2014, 11:39 PM
lost
Quote:
Originally Posted by jchosler View Post
I actually did something similar i welded tab from the hot side pipe to the top of the A/C mount bolt. It ripped off after a year or so due to the rigid mounting. I patched it and left it alone without remounting it to the A/C, no problems since
Yep prob not the best thing to do, I removed my support brackets after Jim and Travis posted. I have since changed the dimensions on my pipes to minimize rubbing and its working great. I'll try and get some updated pics and post them up as an update to this.
Old 08-07-2014, 12:37 PM
cowmilker08's Avatar
cowmilker08 cowmilker08 is offline
cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.cowmilker08 has a good reputation on FTE.
Nice looking system, Chris. I really like the lower IC support you made.
Old 08-07-2014, 04:35 PM
OldWoodsDiesel's Avatar
OldWoodsDiesel OldWoodsDiesel is offline
OldWoodsDiesel is gaining momentum as a positive member of FTE.
i too like the system very much and will add this link to my list of links to shamelessly copy from when it comes to my IC install.
however, i must not have paid enough attention on the other IC threads i've read - why does the hood latch get modified? does the IC want to interfere with it as is?
also, unrelated to your IC, but what is the telephone pole tranformer-looking thing on your firewall in this picture: IMG_20140319_161318.jpg Photo by wcsohazen | Photobucket
does that provide the 1.21 jigawatts to the flux capacitor?
Old 08-07-2014, 09:28 PM
farmert farmert is offline
farmert has a good reputation on FTE.farmert has a good reputation on FTE.farmert has a good reputation on FTE.
That looks like a relay for something to me, with all the wires running to it.
Old 08-07-2014, 11:27 PM
lost
Thanks for the kind words Phil and JP. I hope it helps somebody be able to put in their IC with less trouble.
Lol JP, "Great Scott!" that is a relay that the original owner put in. He had a bed cap and some lights in the bed. I just left it just in case I need it someday.
Depending on what IC you use, the hood latch support strap needs to be flattened, cut out, or weld a new strap in as I did. The factory strap will hit the IC if the IC is mounted close to the a/c condensor/radiator. The hood latch lever will also need bent to allow it to move without hitting the IC.
Old 08-09-2014, 10:43 AM
rodneywar's Avatar
rodneywar rodneywar is offline
rodneywar has a good reputation on FTE.rodneywar has a good reputation on FTE.
the ac line rubbing can be resolved by carefully bending the ac line up and away from the pipes i did that and it clears by a half inch
Rust Attack! Jethrone 6.7L Power Stroke Diesel 17 06-13-2015 11:21 PM
Radiator Core Support Paint Colors/Materials slashfan7964 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 02-05-2015 03:25 PM
Turbo stall? Opinions needed. Chris56ford 1994.5 - 1997 7.3L Power Stroke Diesel 67 07-20-2014 10:15 PM
Riffraff Diesel Billet Compressor Wheel Chris56ford 1994.5 - 1997 7.3L Power Stroke Diesel 2 05-10-2014 04:04 PM
4700 mile round trip to Florida Chris56ford 1994.5 - 1997 7.3L Power Stroke Diesel 9 04-21-2014 12:08 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
