2003 Ford F250SD Security System PATS reset - Ford Truck Enthusiasts Forums
Old 05-04-2014, 12:37 PM
GRUBBY604 GRUBBY604 is offline
GRUBBY604 is starting off with a positive reputation.
Hello everyone,
I am having problems with my vehicle security/remote start system. I have 2003 ford f250 SD with the stock alarm/remote start (RKE/VSS/RMST) with the 4 button key fob (which I can't seem to figure out how to attach a photo of to this post?). I tried to start the truck remotely and realized that my drivers side door was open and it failed, which it is programmed to do in that situation. Somehow I must have triggered the alarm system during this and now the vehicle I suspect has killed the starter as a anti-theft precaution. I can't even start the truck with the key in the ignition.
I downloaded a manual online to program the RKE/VSS/RMST, but it looks like it is for the 2006 model/year, which might be different as it shows a 5 button key fob. I have 2 keys for the vehicle which I am assuming are the stock keys (I bought the truck from the original owner in 2012).
-Does anyone have the proper manual/info to reprogram/reset the PATS?
-Does anyone know which button on the 4 button key fob is the programming/override button?
-Is it as simple as pulling out the module under the dash and reinserting it?
I have called the 1-800-FORD-KEY phone number but they weren't any help, they told me to get it towed to the dealership which would be my last and most expensive option.
Thanks for any help.
Old 05-04-2014, 04:45 PM
Franklin2's Avatar
Franklin2 Franklin2 is offline
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Have you tried the owners manual? Here's a link.
https://owner.ford.com/servlet/Conte...ge&ord=4434452
I can't believe it would be that complicated to get the truck going. You would think once you turned some of the locks and/or the ignition with the proper key(not the key fob) that this would be verification to the system that someone authorized with the proper key is getting ready to operate the vehicle and to reset itself.
Old 05-04-2014, 11:23 PM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
An 03 Super Duty doesn't have PATS.
Old 05-10-2014, 07:32 PM
HomerWinzlow's Avatar
HomerWinzlow HomerWinzlow is offline
HomerWinzlow is gaining momentum as a positive member of FTE.HomerWinzlow is gaining momentum as a positive member of FTE.
try turning the key on and then hit the unlock button and turn the key off. Thats all I can remember from the dealer installed systems from back then. You can always remove all that crap and restore it to OEM
Factory Alarm Woes... brian42 1999 - 2003 7.3L Power Stroke Diesel 0 10-27-2016 06:38 PM
08 Ford Escape RKE programming error dukkman65 Escape & Escape Hybrid 0 12-11-2014 07:11 PM
1 Way Remote Start and key/fob consolidation on 2014 Expedition steveg_nh 2007 - 2014 Expedition & Navigator 2 11-27-2014 12:31 AM
Need assistance programming new key fobs w/aftermarket alarm F350SDKammyo 1999 to 2016 Super Duty 0 10-24-2013 02:19 PM
Can't program a wireless remote key fob TwoMuchMud Escape & Escape Hybrid 3 10-12-2011 12:00 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
