Dampner Install - Ford Truck Enthusiasts Forums
Dampner Install
Old 05-04-2014, 11:28 AM
Outlaw56 Outlaw56 is offline
Outlaw56 is starting off with a positive reputation.
Dampner Install
When installing the dampner, how do you know when it is pulled far enough onto the crank to stop? Will it seat itself then just torque the Bolt?
Old 05-04-2014, 11:52 AM
hiball3985's Avatar
hiball3985 hiball3985 is offline
hiball3985 is gaining momentum as a positive member of FTE.hiball3985 is gaining momentum as a positive member of FTE.
Quote:
You got it.. It will bottom out against the oil baffle and timing gear
Old 05-04-2014, 12:09 PM
Thanks Hiball
vibration dampner GTT78 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-09-2015 09:03 AM
Dampner center bolt torque spec Redworks Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 7 07-27-2015 05:56 PM
6/77 F-250 4x4 shimmy shock/steering dampner options ? Chris Popanz 1973 - 1979 F-100 & Larger F-Series Trucks 1 07-03-2015 10:41 AM
Double Pulley Dampner C3TE-6316-E Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 0 04-15-2014 08:38 PM
Y-Block Dampner Timing Marks Outlaw56 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 22 04-06-2014 06:59 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
