Help with torque specs
05-04-2014, 09:42 AM
on
I can't find the torque spec for the rocker carrier (or cylinder head cover) to the head. It's 8 10mm bolts.
Also the high pressure oil rail torque spec for 03 engine. All my Haynes manual has is the wavy rail. And the old style stand pipe torque spec I can't find. Thanks for any help.
05-04-2014, 10:19 AM
05-04-2014, 10:38 AM
on
Thanks dude. I still can't find the rocker carrier to the head..
05-04-2014, 10:49 AM
on
Would that be the rocker arm fulcrum bolts at 23lbs ft at the bottom of the second page seems kinda light but it might be what you are looking for
05-04-2014, 11:03 AM
Certified Thread Hijacker
18 ft-lbs, then 23 ft-lbs for the upper bolts
Josh
05-04-2014, 12:17 PM
on
Quote:
Originally Posted by
Bullitt390
Josh
This is for the 8 10mm bolts for the rocker carrier to head? 4 on top and 4 on bottom, why are they different torque specs?
05-04-2014, 12:37 PM
RideDiesel88
Oh, my posted specs were for the actual rocker carrier to block
Josh
05-04-2014, 12:39 PM
RideDiesel88
Rocker box to head would be 46 lb-ft.
05-04-2014, 12:44 PM
texastech_diesel
23 ft-lbs , step 6 and final torque as noted above.
Josh
05-04-2014, 08:23 PM
on
Bullitt390
Josh
Step 6? Is there more steps?
05-04-2014, 10:00 PM
on
O I gess if I would look at all the information I would of seen all the steps
05-08-2014, 02:50 PM
on
are you sure this is for the aluminum box to the head? everybody keeps giving info for the small bolts for the head to the block or the rocker arm fulcrum to the aluminum box which is something different. your info seems more like what i'm looking for
FOURBYBUD
2017+ Super Duty
03-11-2019 10:29 PM
mcompton1973
07-25-2018 10:27 AM
haulinirish
08-27-2013 08:41 PM
Benchwrench
10-08-2010 02:39 AM
branning
11-12-2008 09:54 PM
