Triton Engines - Ford Truck Enthusiasts Forums
Triton Engines
Old 05-04-2014, 10:10 AM
Nitro 54 Nitro 54 is offline
Nitro 54 is starting off with a positive reputation.
Triton Engines
Did Ford ever solve the head gasket problems the early 4.6 and 5.4 engines were having ? There seems to have been so many I think a recall should have been issued.
Old 05-04-2014, 10:15 AM
projectSHO89 projectSHO89 is offline
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Head gasket issues rarely comes up around here compared to the more common usual stuff.... misfires, vacuum leaks, EGR issues, etc.
Old 05-04-2014, 11:46 AM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Would be news to me that there is a headgasket epidemic.
Old 08-31-2014, 10:22 AM
JW357 JW357 is offline
JW357 is starting off with a positive reputation.
Won't run under 2500 rpms!!
Hey all,
Just recently picked up a 2000 Ford F150 Triton for $400. The price was right so I figured what the heck! Anyway the previous owner got tired of dealing with it so he sold the truck to me. At first after reading this forum I thought the IAC and vacuum lines could be the problem. Not it at all. The only sensor that has not been replaced is the crank sensor and I believe 1 o2 sensor. Is there any others I could be missing?? The truck ran great one day and then started this problem the next. I'm open to any and all suggestions. Thanks!!
Old 08-31-2014, 02:37 PM
Bluegrass 7 Bluegrass 7 is offline
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
JW, since this is your first post, your forgiven but start your own thread on your issue.
Barging in on an unrelated thread is not productive.
Please give enough detail to have a reasonable chance of getting a direction to go in, to help you.
You really did not give much except for wholesale parts replacement which is not the way to do it as your finding out.
Good luck..
Old 09-01-2014, 04:25 PM
JW, There are 2 sensors under the fuel-air intake above the valley cover. A heat and anti-knock sensor, If I remember right what my mechanic told me. A mouse ate up the wiring all the way to the sensors.
Ford 5.4L 3v Engine Timing Walkthrough makuloco2000 2004 - 2008 F150 1 12-07-2014 01:49 PM
5.4 2V red line pony Modular V8 (4.6L, 5.4L) 2 10-17-2014 12:11 AM
what 5.4 engines interchange roger7.3 1999 to 2016 Super Duty 5 10-09-2011 07:32 PM
2002 5.4 - 2 valve or 3 valve? sawdust57 1999 to 2016 Super Duty 16 04-28-2009 04:08 PM
5.4 types?? Kingsun Modular V8 (4.6L, 5.4L) 7 11-06-2003 10:57 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
