HPOP reseal?
HPOP reseal?
So im on a tight budget right now and as much as id love to buy a new better hpop im wondering if I could reseal it for less? what orings/oring kits would I need? along with any parts/pieces in there that should be changed ive never taken one off/apart before so its new to me
Depends what your problem is. Is the pump leaking and why do you want to reseal? You can't disassemble the actual pump and replace internals.
Some kits from Riffraff Diesel .. High Pressure Oil Pump & Related
Its just leaking is all, I assumed you couldn't replace internals, im just wondering can you do a complete reseal and if so what parts do I all need and would I be better off just buying new pump, I did look at riff raffs hpop stuff but I wasn't sure if that would be everything I needed or not. If its better to get a new one im looking at the T500, is that ok for a stock truck?
econo93
01-24-2019 09:57 PM
cdude20
06-27-2013 08:07 PM
