Uh-Oh, I think Hal is intercoursed - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 05-03-2014, 05:59 PM
WVVan's Avatar
WVVan WVVan is offline
WVVan is gaining momentum as a positive member of FTE.
So I go to start Hal a couple days ago and the starter wouldn't turn the engine over. The starter sounded OK but it sounded like the engine would start to turn over but then just stop. So must be the started I thought.
Just put now put on a new starter and when I went to turn the engine over there was a loud BANG and violent shudder. I instantly turned off the engine and looked under the van to see oil pouring out.
Got the drain pan under there but not soon enough. One advantage of having cats. Big bags of cat litter.
So does this mean what I think it means (new engine needed)?
Old 05-03-2014, 06:05 PM
Tedster9's Avatar
Tedster9 Tedster9 is online now
Tedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputationTedster9 has a superb reputation
Oil pouring out from _where_? Definitely Not Good (tm) tho theoretically it could be the oil filter? Yer gonna have to look. Maybe a rod... Sorry for your loss.
Sent from my iPhone using IB AutoGroup
Old 05-03-2014, 06:24 PM
WVVan's Avatar
It's leaking out of the space just aft and above the crossbrace. Oil filter looks fine.
Old 05-03-2014, 06:33 PM
Tedster9's Avatar
Yeah.. Hal is definitely in trouble.
Old 05-03-2014, 07:43 PM
tims01's Avatar
tims01 tims01 is offline
tims01 has a very good reputation on FTE.tims01 has a very good reputation on FTE.tims01 has a very good reputation on FTE.
rip hal
Old 05-03-2014, 08:42 PM
Tom's Avatar
Tom Tom is online now
Tom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputationTom has a superb reputation
Uh oh, that isn't good! Really sounds like you and Tim have the same lousy luck.
Like the play on words with "intercoursed".
Old 05-04-2014, 05:10 PM
econolinemanor econolinemanor is offline
econolinemanor is starting off with a positive reputation.
Hydro locked start and a rod through the block? My condolences WVVan..........
Old 05-04-2014, 09:16 PM
tims01's Avatar
lol ...
Old 05-06-2014, 09:59 AM
YoGeorge YoGeorge is online now
YoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to beholdYoGeorge is a splendid one to behold
What a bummer, WVVan. I'm guessing you have enough work in the rest of the van that it'll be worth your while putting in a new engine. Good luck finding the right source for a tight rebuild, or a really good used engine. I'd suggest a conversion to a 4.6 but fear that it'll be too complex with wiring harnesses, computers, etc.
And yeah, being a cat owner has been handy, like the time I screwed on an oil filter with the gasket from the old filter still stuck on the mounting surface. But it was much easier for me to laugh off the problem because the cost was only a few quarts of oil....
Best wishes for Hal's resurrection....
George
Old 05-11-2014, 02:43 PM
Tom's Avatar
BUMP!!!
Any update?
Old 05-12-2014, 08:18 AM
JWA's Avatar
JWA JWA is offline
JWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputationJWA has a superb reputation
Poor guy is probably crying about this--I would be after all the amazing work refitting he's done to this van.
Old 05-12-2014, 12:16 PM
tims01's Avatar
just do a motor swap it is anoying but at least the van would be runningn again and reliable?
Old 05-12-2014, 12:35 PM
Quote:
I absolutely agree that the work put into the box warrants a new or rebuilt engine. Again, I would recommend a swap to a 4.6 but that would probably require too many changes with regard to electronics and wiring hookups.
Good luck to you, WVVan; you have been such an asset to our FTE van community. Note that I am also a (road) bicyclist and the prez of a big bike club in Michigan. Big vans rule for carrying bikes and people and stuff...
George
Old 07-02-2014, 08:38 AM
Army RET's Avatar
Army RET Army RET is offline
Army RET has a good reputation on FTE.Army RET has a good reputation on FTE.Army RET has a good reputation on FTE.
Isn't it about time Hal info was updated?
Missing all those updates, upgrades, and pics of carefree supervisor.
Old 07-03-2014, 02:23 PM
Gettysburg150's Avatar
Gettysburg150 Gettysburg150 is offline
Gettysburg150 is gaining momentum as a positive member of FTE.Gettysburg150 is gaining momentum as a positive member of FTE.
x2 on the update, read all WVVan's other threads on putting Hal together, hate to see this "little" road block louse up a good thing
New starter, now no start bc2sv 1999 - 2003 7.3L Power Stroke Diesel 3 05-29-2016 01:22 PM
Converting a 1999 Ford E-250 into a camper van WVVan 1968-2013 Full Size Vans 604 12-05-2015 12:48 AM
starter spinning adamkat22 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 51 09-04-2015 08:53 AM
mini starter ?? mmuenchow FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 3 03-29-2010 05:48 PM
351w cam & torque converter HAL_419 1987 - 1996 F150 & Larger F-Series Trucks 4 01-23-2004 03:03 AM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
