Help with leaky block heater freeze plug! 94 f350 with 460
Replaced cap/rotor/wires/plugs on my 94 F350 the other day, and was letting it idle for a couple minutes before I took it for a drive, when my son noticed a leak underneath the truck. Got under and looked, it was anti-freeze coming from the block heater plug on the passenger side of the block. Further investigation showed the driver side plug had already been replaced, so I am guessing this leak happened before (only had the truck two months). Any ideas for getting this plug out? I'm not worried about the block heater, hadn't previously used it, more worried about not puking out all my coolant. Thanks in advance!
Got it out, gripped the edge with vice grips and gave it a good yank. The retainer on the back was split, thus not allowing for a good seal. Regular freeze plug back in it, got it filled back up and got it good and warmed up, no leaks. Problem solved!
$40 for the plug + antifreeze, and she runs like she ever did. Wonder how much a shop would've charged? $300+?
Danspeed1
01-03-2010 04:36 PM
shendren
01-13-2004 08:48 PM
