POR1 Engine Paint (Let see some pics) - Ford Truck Enthusiasts Forums
Old 05-02-2014, 07:18 PM
MdubbU's Avatar
MdubbU MdubbU is offline
MdubbU is starting off with a positive reputation.
I was just wondering if any one here has used this system and how it held up. I did my motor in it and it turned out great. I just really hope it hold up for a long time.
Heres a few pics of how mine turned out.
Old 05-02-2014, 11:07 PM
77&79F250's Avatar
77&79F250 77&79F250 is offline
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Wow, a whole lot of Ford Blue you have there, any 2 tone in the future? And yes post up its durability.
Old 05-04-2014, 06:24 PM
lafermedavid lafermedavid is offline
lafermedavid is gaining momentum as a positive member of FTE.lafermedavid is gaining momentum as a positive member of FTE.
por
looks great ,did you spray it on.or brush.....Looks like you used por black and then blue,,,,I didnt think you needed to paint a base with the por Ford Blue,,just wondering.I have a 302 and a small can of Ford Dark blue por that I was going to paint.I know por makes a white primer in spray,,just wondering.Looks Great
Old 05-04-2014, 08:54 PM
kwe45919's Avatar
kwe45919 kwe45919 is online now
kwe45919 is starting off with a positive reputation.
Wow....looks good. It sure is blue.........you'll be able to see oil leaks a mile away. Good job. Hope it holds up and is durable...
Old 05-04-2014, 09:02 PM
Jklnhyd's Avatar
Jklnhyd Jklnhyd is offline
Jklnhyd has a great reputation on FTE.Jklnhyd has a great reputation on FTE.Jklnhyd has a great reputation on FTE.Jklnhyd has a great reputation on FTE.
Double post
Old 05-04-2014, 09:03 PM
Jklnhyd's Avatar
Did you paint that all put together? Going to be a mess if you remove components and bolts.
Imo, would look better with block, heads, and bracketing with black.
Old 05-07-2014, 04:10 PM
MdubbU's Avatar
yeah it was painted all put togather. bolts in the oil pan and the bolts on the valve covers came right out plus all the other bolts I had in holes plugging up spots needed for brackets and other parts.
Update F1truckproject 1948 - 1956 F1, F100 & Larger F-Series Trucks 18 12-02-2015 02:50 PM
My 1978 F250 "Truck Norris" TruckNorris250 1973 - 1979 F-100 & Larger F-Series Trucks 46 09-10-2015 10:39 PM
Other hobbies/collections. Countryford83 General NON-Automotive Conversation 28 04-15-2015 09:25 PM
F250 Paint and interior reconditioning PETE'S_6.0PSD Appearance & Dress-Up 2 11-20-2014 02:08 PM
1979 F100 Rebuild MdubbU 1973 - 1979 F-100 & Larger F-Series Trucks 17 05-02-2014 07:50 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
