Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
4.6 DOHC Swap into 96 Ranger
Old 07-23-2014, 07:28 PM
nojoke327's Avatar
nojoke327
nojoke327 is offline
Can you cut the factory coolant crossover tube and flip it up so you don't have to cut the shroud and potentially mess with the cooling abilities.
Also do you have any flow worries from the passenger side header. There are a lot of tight turns and many welded pipes which when cut at an angle can increase or decrease the diameter.
Coming along nicely as always though.
  #32
Old 07-24-2014, 03:01 PM
badranger34's Avatar
badranger34
badranger34 is offline
I suppose I could do that, and it would be the proper way to go about it. I just don't want to have to do any more metal fab. Haha.
I really just have to snip a plastic strip that runs from the shroud to the center of the fan. It shouldn't have any affect on the shroud itself.
Here is a better picture of the clearance.
I guess I am slightly concerned about the passenger side header. I used 1 5/8" tubing, so I should hopefully have enough volume to make up for the tight bend. I basically had to make the 2 really tight bends due to the frame rail and the coil spring perch.
I suppose if I have any issues, I could always go back and hack it up. This was my first attempt at making headers, so there was a big learning curve.
  #33
Old 07-24-2014, 07:55 PM
nojoke327's Avatar
nojoke327
Rework is just part of these custom builds. I hope it doesn't come to that though.
  #34
Old 09-22-2014, 07:12 AM
R.A.D's Avatar
R.A.D
R.A.D is offline
progress? will you do a write up on your rewire?
  #35
Old 09-17-2019, 09:43 AM
jonyboysrngr's Avatar
jonyboysrngr
jonyboysrngr is offline
Hello.Great project! I too am doing a 4.6 ranger swap and I am lost at the steering box stage wanting to know did you use the 70s f150 box as brought up ,or did you find a better way, any help will be greatly appreciated,also my motor mount choice is up in the air and would like any advice you have thanks so much...
  #36
Old 09-18-2019, 07:47 PM
85e150's Avatar
85e150
85e150 is online now
Received 1,584 Likes on 1,292 Posts
Welcome to FTE. This might be all the advice you get from that fellow. He was last here 5 years ago.
Feel free to start your own thread in the Ranger forum:
https://www.ford-trucks.com/forums/forum35/
Good luck!
a.s.k.52
87
06-01-2018 07:09 AM
hautofox
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
06-27-2006 07:16 PM
bigader
4 Cylinder Engines
11-20-2003 06:06 PM
Andysutt
1983 - 2012 Ranger & B-Series
04-01-2003 07:17 PM
Quick Reply: 4.6 DOHC Swap into 96 Ranger
