4.6 DOHC Swap into 96 Ranger - Page 3 - Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
  #31
Old 07-23-2014, 08:28 PM
nojoke327's Avatar
nojoke327 nojoke327 is offline
nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.nojoke327 has a good reputation on FTE.
Can you cut the factory coolant crossover tube and flip it up so you don't have to cut the shroud and potentially mess with the cooling abilities.
Also do you have any flow worries from the passenger side header. There are a lot of tight turns and many welded pipes which when cut at an angle can increase or decrease the diameter.
Coming along nicely as always though.
  #32
Old 07-24-2014, 04:01 PM
badranger34's Avatar
badranger34 badranger34 is offline
badranger34 is starting off with a positive reputation.
I suppose I could do that, and it would be the proper way to go about it. I just don't want to have to do any more metal fab. Haha.
I really just have to snip a plastic strip that runs from the shroud to the center of the fan. It shouldn't have any affect on the shroud itself.
Here is a better picture of the clearance.
I guess I am slightly concerned about the passenger side header. I used 1 5/8" tubing, so I should hopefully have enough volume to make up for the tight bend. I basically had to make the 2 really tight bends due to the frame rail and the coil spring perch.
I suppose if I have any issues, I could always go back and hack it up. This was my first attempt at making headers, so there was a big learning curve.
  #33
Old 07-24-2014, 08:55 PM
nojoke327's Avatar
Rework is just part of these custom builds. I hope it doesn't come to that though.
  #34
Old 09-22-2014, 08:12 AM
R.A.D's Avatar
R.A.D R.A.D is offline
R.A.D is starting off with a positive reputation.
progress? will you do a write up on your rewire?
Axle and inner seal questions? F0rdc0wb0y 1999 - 2003 7.3L Power Stroke Diesel 34 Yesterday 11:49 AM
Name that melted relay! DrZoom 1987 - 1996 F150 & Larger F-Series Trucks 15 01-12-2017 07:25 PM
Re-pinning Harness badranger34 Electrical Systems/Wiring 7 05-14-2014 10:03 AM
New to me 56 small window F100 Vin Man 1948 - 1956 F1, F100 & Larger F-Series Trucks 28 02-12-2014 02:19 PM
Cherrybomb extreme instsalled + video+ other Mods!!!! Bladely Modular V10 (6.8l) 23 12-29-2009 04:15 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
