53 F100 interior door & window handle removal
Removing those door handles with the wire clip doesn't require a special too. I learned from an old timer boss that all you need is a shop rag. Just take hold of two corners on the same side of the rag, slide between the door handle and the door pull gently towards the handle shaft, then bring the corners of the shop rag towards each other on the opposite side of the handle at about a 30 degree angle, then slide in one direction. The rag will grab one of the ears on the clip and pop it right out. Works every time.
Barry Eck
09-19-2011 09:52 AM
JimG1098
09-09-2008 01:08 PM
Drool Monkey
08-01-2004 03:24 PM
tortoise
06-19-2003 09:20 PM
