1994 F150 question for someone with a wiring diagram - Ford Truck Enthusiasts Forums
Old 05-02-2014, 10:46 AM
BuickBrian's Avatar
BuickBrian BuickBrian is offline
BuickBrian is starting off with a positive reputation.
I am working on a 1994 F150 for someone and it has a been switched back to a carbureted V8 engine. It was originally a 300-6 truck. Has a factory tach in the dash that reads incorrectly since the wiring harness is for a 300-6, not a V8. There is a pin in the big square engine wiring harness connector under the hood that if grouned will set the tach for a V8 engine. Anyone out there with a wiring diagram that could tell me which pin in the connector needs to be grouned to switch the tach to V8 mode?
Old 05-03-2014, 10:22 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
You just need to ground pin #10 of C250 at the cluster.
Old 05-08-2014, 10:17 AM
BuickBrian's Avatar
Thanks for the info! They are bringing it to me later this week, so I will tear into it and see what I find.
1997 e350 w/v10 wiring schematics Bones929K 1968-2013 Full Size Vans 6 06-15-2016 07:55 AM
Windshield wiper motors Intimnasc 1987 - 1996 F150 & Larger F-Series Trucks 2 03-09-2016 06:33 AM
mutifunction switch 7 pin pigtail connector ditchdragah 1997 - 2003 F150 0 03-23-2014 11:00 AM
Cluster wiring- add a tach? Handegard 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 02-22-2014 11:27 AM
v8 tach cluster into I6? f100beatertruck 1987 - 1996 F150 & Larger F-Series Trucks 10 09-14-2013 01:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
