PM 22
Well I am surprised to see at the Ford site, it does not mention it's use in a 6.7.
Motorcraft® Brake & Engine Performance Fluid & Cleaners
•Note: This ultra-low sulfur formulation can be used in engines required to meet 2007 emissions requirements (e.g., Ford’s 6.4L diesel engine) and is backward compatible as well (i.e., can be used in Ford’s 6.9L, 7.3L and 6.0L diesel engines)
I can see why he might think so as Ford does not specifically state it is for 6.7 on that page. He may be reading too much into that though.
This info sheet on PM22 lists the 6.7, http://mobile.powerstrokediesel.com/...FuelDollar.pdf
I think that one factor in how well PM22 (or any other additive) works is dependent on the fuel quality you get from the pump. Since diesel only needs to be 40 Cetane and Ford recommends 45. Any additive I would use would increase the Cetane and PM22 does.
I notice a difference in how the motor sounds/runs as well as the MPG. I get more of a traditional diesel sound when the fuel I put in is not high quality. Not obnoxious, just noticeable to me as no one in the vehicle ever notices when I ask.... Even though I typically add an additive at fill up time, sometimes I end up adding a little more in or if it continues to be noticeable I fill up early again. Since it is warm where I currently live, making the tank B20 also cures the sound and makes the truck run smoother, but you don't get better MPG running BioDiesel. I also get B99 from a supplier that turns over as much as he can get from the refinery so I am typically running 2 week old Bio when I do run it. I have not run it in a while and probably should as it helps clean out the DPF which is helpful for my city only driving.
I know where to get decent fuel locally, most of the time I run into this problem "on the road".
But that's why we got PM-22
You can tell which station is selling the good stuff within a few miles after filling up.
